watchers for every issue
Diane Arsenault
Hello Friends,
Your favorite newbie here! I have a very basic question. I have a project lead who has made the following request: Can we build a default list of watchers for the project? We have a group that should be made watchers for every issue.
Here is what I think: I can make a list of users and give them certain set permissions. There isn't a project role called watcher.
Thoughts? Thanks. Diane
Natalie Hobson
August 8, 2012
You could also create a new role if you prefer that to adding a group:
https://confluence.atlassian.com/display/JIRA/Managing+Project+Roles
Ravi Shah March 25, 2020
I was able to add a default watcher by simply creating an automation rule at the event (trigger) of New Issue Created, followed by certain conditions which are called components in automation rule config. No Plugins are required to do so and we can choose this rules at global level or at project level as well.
HTH :)
Jobin Kuruvilla [Adaptavist]
August 7, 2012
I think Bug watcher plugin does this. We used to use a Component Watcher plugin too which watches components.
Howveer, you can probably get the same watcher functionality by adding groups directly into notifications provided you can create a new notification scheme for the project. This becomes painful if you want this functionlity for all projects and that is when the plugins will help!
