what are these component icons? and how do you remove them?
Joseph Huynh
Shannon S
February 13, 2018
Hi Joseph,
It seems that you may have run into this issue, if you're on Jira Cloud:
If you set the components in the X-Axis as displayed on that bug, the problem will not occur.
Could you have a look at that bug and confirm if setting to X-Axis stops the problem? If so, please vote on the bug to show that you are also affected and feel free to comment with your feedback.
Shannon
Ana Gomez-Espinosa October 19, 2018
This setting to X-Axis does not resolve the problem
Shannon S
October 19, 2018
Hi Ana,
Would you be able to show me how it looks for you after after you set the components to the x-axis?
I've tested in my own instance, but I'm not able to replicate the issue:
X-Axis:
Y-Axis:
Shannon
