what is the custom field default value?
duy tran quang September 11, 2014
I have created a custom field (my_customfield) based on "Version Picker (single version)" and have noticed that the default value is "Unknown".
However while running the query: my_customfield = Unknown => The value 'Unknown' does not exist for the field.
note that my_customfield is EMPTY returns a list but not all my issues.
Thanks for your help
duy tran quang September 12, 2014
Thanks for your prompt answer however neither null nor empty return the expected list.
Anna Cardino
September 12, 2014
Hi
Can you try "null" or "empty" instead of "unknown"?
Monique
