what is the proper syntax to update JIRA issue priority in a workflow post-function?
Jeannette Lamb
I'm using the built in script to clone an issue and my conditions appear to be working correctly because the clone is successful but I also want to add a additional issue action to set the priority of the resulting clone. I've tried " issue.priority?.name == 'Blocker' " and a few other options but the priority is always left unset in the clone.
Thank you.
JamieA
May 16, 2013
Try:
issue.priorityId = '1'
where '1' I think is blocker, and '5' is minor IIRC.
if you use issue.priority you need to provide a GenericValue - see https://developer.atlassian.com/static/javadoc/jira/5.0.5/reference/com/atlassian/jira/issue/MutableIssue.html
Jeannette Lamb
Thank you! that worked.
