I'm trying to create subTasks to an Issue.
In my code I create the Issue first and then I try to create SubTasks via issueService.validateSubTaskCreate(.....) and so on.
when I run my plugin it creates the normal Issue just like I intended. but gives me an exeption:
java.lang.IllegalStateException: You can not create an issue with an invalid validation result.
I've tried different things up until now. I tried getErrorCollection() on the validationResult, which came back empty. But when I tried isValid() it returned false and I have no idea why since I did everything like I did with the main Issue
here's what I did:
public List<IssueInputParameters> subTaskParameters(Issue newIssue, Issue oldIssue){ List<IssueInputParameters> newParams = new ArrayList(); List<Issue> currentSubTasks = (List<Issue>) oldIssue.getSubTaskObjects(); for(Issue issue : currentSubTasks){ IssueInputParameters input = issueService.newIssueInputParameters(); input.setDescription(issue.getDescription()); input.setIssueTypeId(issue.getIssueTypeObject().getId()); input.setProjectId(issue.getProjectObject().getId()); input.setSummary(issue.getSummary()); input.setAssigneeId(getLoggedInUser().getDisplayName()); newParams.add(input); } return newParams; } public void createSubTasks(Issue newIssue, Issue oldIssue){ List<IssueInputParameters> subTaskParams = subTaskParameters(newIssue, oldIssue); for(IssueInputParameters params : subTaskParams){ CreateValidationResult createValidationResult = issueService.validateSubTaskCreate(getLoggedInUser(), newIssue.getId(), params); IssueResult result = issueService.create(getLoggedInUser(), createValidationResult); } }
Thanks beforehand.
Alright! I got it. just forgot to set the Reporter^^
Could it be failing because the parent issue is not created by the time you get to the subtasks? I think that might cause a validation failure with no actual results (it used to in version 3)
