workflow how to remove a global transition?
Marc Minten _EVS_
June 15, 2015
I have a workflow with a state with two incoming GLOBAL transitions (they have exclusive conditions). How can I remove one of both? In text editing mode, I cannot find any way to remove a global transition. In diagram-mode I see only one small black box with text 'All' one of the two transitions is hidden below the other ?). How can I access the 'other' one ? I can only select the one that is 'on top' sad
Thx
By the way, this workflow designer is probably the worst designer I have ever seen smile
Fidel Castro
July 14, 2015
Hi Marc,
To do it you will have to use Diagram mode. Look at this example of how to do it:
  1. Click on the two overlapped transition for selecting them. The you will se a back dot at the tip of the transition:
  2. Move the black dot to another place in the border of the same status. This way you will attain to let the transition below to be seen:
3.- Now you can select the global transition (the one labeled with All) and delete it:
Fidel
