workflow problem
Davor
How to add a custom button in issue window
problem is that now when i would like to add custom action
i need to go to workflow and that select it.
So i would like to add that field near the resolve issue button
NielsJ
December 15, 2011
You can adjust the number of shown buttons:
http://confluence.atlassian.com/display/JIRA/Configuring+Workflow#ConfiguringWorkflow-ChangingtheNumberofTransitionButtons
If there are more possible workflow transitions as buttons, they will go into that Workflow menu :-)
