worklogDate JQL query does not reflect the timeframe selected.
Smita
I am using JIRA Software 7.2.4 and I have an issue with JQL using worklogDate() function.
I am specifying the date range as worklogDate > "2019/01/01" but the time spent or work log column shows very minutes logged till date instead of what is logged January 2019 onwards.
Tarun Sapra
February 4, 2019 edited
Hello @Smita
The JQL query is for filtering the issues, and the columns in the issue navigator are for showing the actual data. In a way both things are mutually exclusive, because you used "worklogDate " to find the issues which you were intersted in and the issue navigator displayed the relevant issue columns. You can't at run-time make the time-spent column display only the work logged after the date which has been used in the query.
Smita
Hi @Tarun Sapra, I am slightly confused here. How should I modify the query and view results then? All I would like to do is, get the time logged for all relevant issues for a specified person in a given sprint.
So I need to specify the date range right?
Jean-Michel Bernard
Hello
@Tarun Sapra
Thanks for the clarification, as I was searching exactly for this feature.
I have searched for a related issue in Jira, I found this one and contributed one comment about it.
@Smita Feel free to vote and contribute as well with your use case: https://jira.atlassian.com/browse/JRACLOUD-12312
Thank you
JM
Jean-Michel Bernard
There is also the Jira Server issue (basically the same idea):
https://jira.atlassian.com/browse/JRASERVER-12312
Register now
