Automatically transitioning an issue where its linked issue in another project is closed
icould
I have two projects, let's call them A and B. It rarely happens that some tasks in A project needs some additional work in project B. In this case, I have created an automation to duplicate the issue in project B and link it. This works like charm. Now, I want to do the following (I have 3 different scenarios to achieve the same):
- [project A] if the linked issue is closed, transition the issue to another status.
or
- [project B] if there is an issue closed and if there is a linked issue to project A then transition the linked issue in project A to another status
or
- [project B] if there is an issue closed and if there is a linked issue to project A then trigger an event
   if the event is triggered, transition the linked issue to another status in project A
I tried to implement above ideas from top to bottom but I couldn't achieve any of those using automation for jira add-on. The first one, implementing the if part is easy but I couldn't figure out how to transition the linked issue (ideally with some criteria like if the linked issue is in project A). The second one is similar to the first one. The third one, triggering an event is feasible but trigger somehow needs to know which issue has triggered it so that it can check the linked issue then transition that issue into another status.
Could anyone help me how to achieve this? Either by guiding me implementing on of those 3 ideas or giving a fourth option.
Scott Harwood
October 18, 2017
You should be able to use the same kind of rule for your other conditions also. Let me know if you need any help crafting them.
Scott
icould
Hi Scott,
Do you have an answer to my question below? And also can I specify the issues in which project to transition? In the current implementation, it doesn't check the target project. It just transitions any issues in any projects that are cloned.
icould
Ok I found it. Thanks anyway.
Sebastián Delmastro
I have the same problem @icould. How do you solved it?
icould
Hi @Sebastián Delmastro
I can help if you post your audit log. If it is just the same as mine, then check your if query. You can also verify the query in Jira search, just to see if it returns anything.
icould
Hi Scott,
I have just tried what you have described but there is still something missing. The audit log says that "No related issues could be found". I believe it simply says there is no link found in the RND-407? But actually there is a linked issue. Can you shed some light please?
Note that the linked issue is in another project.
Ben Wagner
February 12, 2019
I am also having this issue.  Did you end up getting a resolution to this?
Vasco Nunes May 8, 2019
Same problem here
