Automation for JIRA time estimation editing issue
Stanisław Juźwicki
I have an issue with a relatively simple automation rule, I would be grateful if you could point out if I am making a mistake here. The requirement is: whenever an issue of "Sub-task" type is set to "Done", the rule should zero-out the remaining time estimate on that sub-task.
So I have a rule that looks like in the screen below. It does work correctly in a way that it does zero out the remaining estimate. However, it also zeroes out the Original estimate - and that is definitely not something I want. Is that a known issue, or should I use a different syntax in the Additional fields box?
Michael Kuhl {Appfire}
September 27, 2019 edited
Hi Stanislaw - Your advanced editing looks right.  Perhaps a workaround would be to set the original estimate as well, but use the smartvalue for the issue to set it to it's current values like this:
"originalEstimate": "{{originalestimate.value}}"
Nick Menere
September 29, 2019
Yeah, this is annoying as the API zeros out the value unless you explicitly set it.
The better option is to select the Time Tracking field from the field list and set the remaining - we do the smarts in the back end to ensure it works as expected.
Nick [Automation for Jira]
Co-founder
Stanisław Juźwicki
Thanks, Nick, this worked like a charm :)
Alexandru Vlaicu
June 15, 2021
Hi @Nick
We are using Cloud Jira.
I'm trying to automate and copy a value from a custom field (only accepts integer numbers) to OriginalEstimate, when I transition a ticket from In Developement to QA Ready.
I've tried multiple scenarios:
1.
"fields": {
"timetracking": {
"originalEstimate": "{{issue.customfield_10211}}"
2.
Define in automation the variable {{timeFromQA}}
then
try editing with automation the originalEstimate field:
"fields": {
"timetracking": {
"originalEstimate": "{{timeFromQA}}"}
Please advise!
3 votes
Dan H
Hello, this doesn't seem to work at all for Next Gen projects, so gutted :'(
Have attempted using the following:
   "fields": {
    "timetracking": {
      "remainingEstimate": "0",
"originalEstimate": "{{timetracking.originalEstimate}}"
which works perfectly for Classic Projects but we receive an error mentioning the 'timetracking' field when using this advanced automation rule on Next Gen projects.
Please help!
Christophe Noualhat
Why are you not using a post-transition rule in your workflow to do that ?
