Automation for jira lite error
Tonio November 30, 2021
I am working in a little personal proyect, and I updated my plugin of Automation for jira lite. When I did it the plugin fail every time in the trigger.
I paste a log here.
Help me, please.
va.lang.RuntimeException: com/codebarrel/automation/api/thirdparty/EventTriggerRuleComponent. Listener: com.codebarrel.jira.plugin.automation.event.JiraIssueEventListenerImpl event: com.atlassian.jira.plugins.inform.performance.events.PerformanceEvent
at com.atlassian.event.internal.SingleParameterMethodListenerInvoker.invoke(SingleParameterMethodListenerInvoker.java:57)
at com.atlassian.event.internal.AsynchronousAbleEventDispatcher.lambda$null$0(AsynchronousAbleEventDispatcher.java:37)
at com.atlassian.event.internal.AsynchronousAbleEventDispatcher.dispatch(AsynchronousAbleEventDispatcher.java:85)
at com.atlassian.event.internal.LockFreeEventPublisher$Publisher.dispatch(LockFreeEventPublisher.java:220)
at com.atlassian.event.internal.LockFreeEventPublisher.publish(LockFreeEventPublisher.java:96)
... 2 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy530.publish(Unknown Source)
... 2 filtered
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:185)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:136)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
at com.sun.proxy.$Proxy1290.publish(Unknown Source)
at com.atlassian.jira.plugins.inform.performance.MeasurementWorkerFactory$1.publishEvent(MeasurementWorkerFactory.java:55)
at com.atlassian.jira.plugins.inform.performance.MeasurementWorkerFactory$1.measure(MeasurementWorkerFactory.java:47)
at com.atlassian.jira.plugins.inform.batching.cron.BatchNotificationJob.runJob(BatchNotificationJob.java:84)
at com.atlassian.jira.plugins.inform.batching.cron.ConditionalJobRunner.runJob(ConditionalJobRunner.java:33)
at com.atlassian.jira.plugins.inform.batching.cron.OncePerClusterJobRunner.runJob(OncePerClusterJobRunner.java:46)
at com.atlassian.scheduler.core.JobLauncher.runJob(JobLauncher.java:134)
at com.atlassian.scheduler.core.JobLauncher.launchAndBuildResponse(JobLauncher.java:106)
at com.atlassian.scheduler.core.JobLauncher.launch(JobLauncher.java:90)
at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.launchJob(CaesiumSchedulerService.java:435)
at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeClusteredJob(CaesiumSchedulerService.java:430)
at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeClusteredJobWithRecoveryGuard(CaesiumSchedulerService.java:454)
at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeQueuedJob(CaesiumSchedulerService.java:382)
at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.executeJob(SchedulerQueueWorker.java:66)
at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.executeNextJob(SchedulerQueueWorker.java:60)
at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.run(SchedulerQueueWorker.java:35)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NoClassDefFoundError: com/codebarrel/automation/api/thirdparty/EventTriggerRuleComponent
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.defineClass(BundleWiringImpl.java:2410)
at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.findClass(BundleWiringImpl.java:2194)
at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1607)
at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.loadClass(BundleWiringImpl.java:2053)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.apache.felix.framework.Felix.loadBundleClass(Felix.java:1927)
at org.apache.felix.framework.BundleImpl.loadClass(BundleImpl.java:978)
at com.atlassian.plugin.osgi.util.BundleClassLoaderAccessor.loadClass(BundleClassLoaderAccessor.java:43)
at com.atlassian.plugin.osgi.factory.OsgiPluginInstalledHelper.loadClass(OsgiPluginInstalledHelper.java:52)
at com.atlassian.plugin.osgi.factory.OsgiPlugin.loadClass(OsgiPlugin.java:209)
at com.atlassian.plugin.module.ClassPrefixModuleFactory.getModuleClass(ClassPrefixModuleFactory.java:44)
at com.atlassian.plugin.module.ClassPrefixModuleFactory.createModule(ClassPrefixModuleFactory.java:27)
at com.atlassian.plugin.module.PrefixDelegatingModuleFactory.createModule(PrefixDelegatingModuleFactory.java:88)
... 2 filtered
at com.sun.proxy.$Proxy260.createModule(Unknown Source)
... 2 filtered
at com.sun.proxy.$Proxy6831.createModule(Unknown Source)
at com.codebarrel.jira.plugin.automation.thirdparty.ThirdPartyComponentModuleDescriptor.getModule(ThirdPartyComponentModuleDescriptor.java:51)
at com.codebarrel.jira.plugin.automation.thirdparty.ThirdPartyComponentModuleTracker.getHandledEventClasses(ThirdPartyComponentModuleTracker.java:49)
at com.codebarrel.jira.plugin.automation.thirdparty.ThirdPartyComponentModuleTracker.lambda$getThirdPartyTriggers$0(ThirdPartyComponentModuleTracker.java:44)
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:174)
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708)
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499)
at com.codebarrel.jira.plugin.automation.thirdparty.ThirdPartyComponentModuleTracker.getThirdPartyTriggers(ThirdPartyComponentModuleTracker.java:45)
at com.codebarrel.jira.plugin.automation.event.DefaultEventRuleRegistry.handleEventWithThirdPartyTriggers(DefaultEventRuleRegistry.java:404)
at com.codebarrel.jira.plugin.automation.event.JiraIssueEventListenerImpl.handleAllOtherEvents(JiraIssueEventListenerImpl.java:176)
... 2 filtered
at com.atlassian.event.internal.SingleParameterMethodListenerInvoker.invoke(SingleParameterMethodListenerInvoker.java:42)
... 46 more
Caused by: java.lang.ClassNotFoundException: com.codebarrel.automation.api.thirdparty.EventTriggerRuleComponent not found by com.tuncaysenturk.jira.plugins.time-to-sla-plugin [280]
at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1639)
at org.apache.felix.framework.BundleWiringImpl.access$200(BundleWiringImpl.java:80)
