Sign up Log in
Automation trigger for value in field is set
frank lohfeld February 21, 2024
how can i build (with Jira automation) that an Rule only starts if the value for the storypoint fiels set from EMPTY to an real value?
The trigger should not start if the the value in Storypoint changed from an real value to an other value (ie from 5 to 3)
Thanks in Advanced
Kalyan Sattaluri
February 21, 2024
Hello @frank lohfeld
You could use If conditions to check this. Something like below, your rule will be after If condition satisfies, so instead of logging like I have, you write you next actions. let us know if questions, please share screenshot.
the first test shows very good - it works like demanded.
Thank you very much
Upcoming Apps & Integrations Events
