Avatar Server for Jira does not work for bitbucket
Allan Margono January 31, 2019
I have the bitbucket.properties per
https://confluence.atlassian.com/bitbucketserver/bitbucket-server-config-properties-776640155.html#BitbucketServerconfigproperties-Avatars
and the avatar didn't get displayed.
It worked for Bamboo.
Does anyone have the same experience?
Thanks.
Fabrizio Giustina
April 6, 2019
Hi @Allan Margono,
configuring the avatar.url.format.http and avatar.url.format.https urls with the proper jira base url should work properly for bitbucket. You also need to check "Enable Gravatar support" in the bitbucket administration, maybe that's the missing bit?
