Behavior for requiring IssueLink when setting resolution to duplicate
Nathan Parmeter November 9, 2018 edited
Setting up a behavior for requiring  an IssueLink when setting resolution to duplicate.
have this:
def resolutionField = getFieldByName("resolution")
def linksField = getFieldByName("issuelinks")
def resolution = resolutionField.getValue()
if (((IssueConstant) resolution).getName() == "Duplicate") {
linksField.setRequired(true)
linksField.setHidden(false)
else {
linksField.setRequired(false)
However im getting the following error:
[common.UserScriptEndpoint]: Script console script failed: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script15.groovy: 5: unable to resolve class IssueConstant @ line 5, column 5. if (((IssueConstant) resolution).getName() == "Duplicate") {
Assistance would be appreciated, I'm sure I am missing something but cant figure it out.
Neta Elyakim
November 11, 2018 edited
You are missing the import for IssueConstant, and you need to take the fields as Id and not by name (those are system fields)
Use this:
import com.atlassian.jira.issue.IssueConstant
def resolutionField = getFieldById("resolution")
def linksField = getFieldById("issuelinks")
else {
Nathan Parmeter November 13, 2018
Thank you, figured it was something simple I was missing.
Like Neta Elyakim likes this
