USE CASE:
we have a nightly data extract that is dropped in a file location
1. We move(manually) it to folder A
2. We extract(manually) issue data from Jira and save that file in folder A
3. Execute(manually) a SPSS script that uses the two files above to create Issues_New_Updates.CSV file
4. The CSV is uploaded(manually) to JIRA to Create new issues and update existing issues.
Could Jira CLI be used to automate all or some of these steps?
If so which steps? Where are the best resources to learn how to do this?
Any help or advice is appreciated.
Thank You!
Ernesto
Yes, likely depending on what the specifics details are. Actions you might want to consider are:
See the reference.
