Changing field by project
uri shech December 13, 2017
I'm using the add-on Multi Level Cascading Field with 3 levels. The first level is similar to our list of projects. We created it this way so it will be easy to choose next level of this field (long list per project).
Is there an add-on or a way that we won't need the first level of the cascading field and the second level will update according to the project name from the begining?
somethingblue
December 13, 2017
Hi Uri,
You may want to take a look at ScriptRunner.  There is an Adaptavist knowledge base article titled Set a mutiselect list custom field value as mandatory that leads me to believe this may be possible with this add-on.
Branden
uri shech December 14, 2017
Thanks.
I'll check it out
(we are already using ScriptRunner)
Nic Brough -Adaptavist-
December 13, 2017
Use a standard "cascading select" list with different contexts by project.
Hi Nic,
Can you explain more? I'm not fimiliar with different context by project.
atlassian, confluence, confluence for marketers, atlassian community events, ace, confluence training, confluence marketing workflows, atlassian learning, marketing tools, content marketing, marketing pm, atlassian live learning, confluence for teams​
Great marketing starts with Confluence. Join our live learning sessions to learn how! 📹
Join our 3-part live learning series with community leader Robert Hean to master how to leverage Confluence for Marketing teams. Learn how to plan and execute on projects seamlessly and how to turn insights into lasting organizational knowledge. 🧠
Register today!
