Hi.
I want to do a fast track transition with the following condition, but it doesn't work...
issue.assignee.getName() !=
'dispatcher'
--> It is the issue creation transition.
Thanks in advance.
Petra
Thanks a lot for your fast answer.
I think, I have to add some more information...
I used script-runner function fast-track as post function.
Hi, The condition seems to be ok. Is the transition valid from current status to use the DISPATCH transition?
Hmm... is the assignee field filled? If the assignee is not present then you will get NullPointerException with this condition... maybe try {code}issue.assignee?.name != "dispatcher"{code}
The assignee is filled automatically with the component lead. I'll try the other syntax. Thanks a lot for your help.
Issue creation transition doesn't have conditions (only validations and post functions).
