is it possible to connect and sync more than 2 JIRA instances with this plugin in parallel (e.g. have one (dual mode) connection from JIRA A to JIRA B and another (dual mode) connection from JIRA A to JIRA C)?
Of course each issue should be synced only with one dedicated external JIRA project in a 1:1 relation.
Best regards
Robert
Yes, it is possible. You can connect as many JIRAs as you like. Each connection (A<->B, A<->C) can have different sync parameters (i.e. fields and triggers).
I represent a vendor of such solution called IssueSYNC. It works for
- cloud
- server
- data center deployments
and supports different Jira version 6, 7, 8 and Jira editions
- Core,
- Software,
- Service Desk.
You setup whole integration via UI and you can let your project administrator's to setup/tune own synchronization for remote Jira connections prepared by sys admin before.
If you have more questions feel free to ask support.
