Copy Actions within same Automation Rule
Arun Makhija
I have created a Automation Rule, which gets triggered when a specific type of Issue is created.
The rule needs to create more than 10 Sub-tasks for the triggering issue
the fields being set for these 10 sub-tasks are same except name and I have to do these values set repeatedly (fields like assignee, reporter, priority etc.)
Is there a way I can copy the 1st action I created 10 times and just change the name ?
Natalia Golikova
Hey,
It will be very helpful to have an opportunity to copy the tasks inside the rule.
It is a lot of work to create almost the same tasks with subtasks every time.
For example, I have a task to deploy a feature and 5 sub-tasks. Now I need 4 different features with almost the same subtasks. It is time consuming.
Natalia
Anand October 25, 2020
I would love this feature. I am creating a bunch of issues via action which more or less similary and it would be great if I can copy these actions. :(
Sherryl Radbil
On Apr 09, 2018 Mark wrote:
"since they're usually pretty quick to create and once you do and it's a do once and your done kinda thing."
I do agree with "your done kinda thing", but not with pretty quick to create.
I have to create a lot of tickets in a Epic that are similar and set 10 custom fields each. Most of the custom field values are the same, with only 2 differing. If I could have copied the component that would have saved a ton of time.
I believe this ticket is related: JIRAAUTOSERVER-261 Ability to copy components when creating/updating a rule
 Please vote for that, I'm surprised that at this moment there are only 3 votes.
Deleted user April 9, 2018
Hey there Arun,
There's no real way to copy components of a rule since they're usually pretty quick to create and once you do and it's a do once and your done kinda thing.
If you really need to you could use the "Advanced fields" section which uses Jira's JSON format directly. That would be easier to copy and paste between the components. https://docs.codebarrel.io/automation/smart-fields/advanced-fields.html
Mark C
Arun Makhija
Thank you Mark.
I could and have tried the Advanced field but faced a challenge in setting and using Multi-Value field like Labels
I used below to set labels from the Parent issue, but if the parent has multiple labels, it errors out. for e.g. Label1,Label2. somehow it doesn't like the Comma
"labels": [ "{{issue.fields.labels}}" ],
But when I used the fields, it copies the whole Labels value to the child Issue
Any clue or suggestions ?
Regards
Arun
Jesse Hamburger
May 4, 2022
For what it's worth, they are definitely not that quick to create, especially if you're creating dozens across multiple rules.
Like • 6 people like this
Paul Campbell February 21, 2023
If you would like this added functionality vote here for it: https://jira.atlassian.com/browse/AUTO-29
Wim Matthijs
We are creating QA scenario tasks for our QA.
each task has to inherit some stuff from an epic and needs to be properly assigned and so on, some labels and stuff.
using smart values to makes sure it all make sense.
Just timed it and it takes 2 minutes for one simple task. (manually copying all the info)
We are running hundreds of scenarios.....
Please upvote
E7 Ana Galofre Smith February 2, 2023
Same here! Is there a cloud ticket we can vote on?
Patrick Van Tassell August 16, 2022
I would love this too.  Just created 8 separate Rules just so I didn't have to copy paste the actions.
