Create Subtask Script not working Script workflow function : Create a sub-task.
Marcel J. Wüstner November 18, 2015
Hello, we've been using script-runner since quite a while but upgraded now to JIRA 7.0 and also script runner to 4.2.
However our post-functions on transitions which creates subtasks are not working anymore.
I set the subtasks according to this:
Subtask will be created with issue type: Sub-task
Target Issue Type: Sub-Task
issue.summary = sourceIssue.summary + ' - Upload'
everything else is empty. This setup worked before transitioning to JIRA 7.0
In the log file i get this error message:
2015-11-18 11:46:22,924 http-nio-8082-exec-6 ERROR mwuestner 706x58402x1 khtkk0 46.165.234.130,127.0.0.1 /secure/WorkflowUIDispatcher.jspa [c.o.s.jira.workflow.ScriptWorkflowFunction] *************************************************************************************
2015-11-18 11:46:22,924 http-nio-8082-exec-6 ERROR mwuestner 706x58402x1 khtkk0 46.165.234.130,127.0.0.1 /secure/WorkflowUIDispatcher.jspa [c.o.s.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: GME-5927, actionId: 571, file: null
com.atlassian.jira.exception.CreateException: An unknown exception occured executing Validator com.atlassian.jira.workflow.SkippableValidator@c6c3e62: root cause: java.lang.NullPointerException
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:748)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:636)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssueObject(DefaultIssueManager.java:761)
at com.atlassian.jira.issue.IssueManager$createIssueObject$0.call(Unknown Source)
at com.onresolve.scriptrunner.canned.jira.utils.AbstractCloneIssue.doScript(AbstractCloneIssue.groovy:112)
at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.CreateSubTask.super$2$doScript(CreateSubTask.groovy)
at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.CreateSubTask.doScript(CreateSubTask.groovy:123)
Caused by: com.atlassian.jira.workflow.WorkflowException: An unknown exception occured executing Validator com.atlassian.jira.workflow.SkippableValidator@c6c3e62: root cause: java.lang.NullPointerException
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:909)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:737)
... 6 more
Caused by: com.opensymphony.workflow.WorkflowException: An unknown exception occured executing Validator com.atlassian.jira.workflow.SkippableValidator@c6c3e62: root cause: java.lang.NullPointerException
at com.opensymphony.workflow.AbstractWorkflow.verifyInputs(AbstractWorkflow.java:1523)
at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:615)
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:879)
... 7 more
Caused by: java.lang.NullPointerException
at com.atlassian.jira.workflow.validator.AbstractPermissionValidator.hasUserPermission(AbstractPermissionValidator.java:49)
at com.atlassian.jira.workflow.validator.PermissionValidator.validate(PermissionValidator.java:46)
at com.atlassian.jira.workflow.SkippableValidator.validate(SkippableValidator.java:53)
at com.opensymphony.workflow.AbstractWorkflow.verifyInputs(AbstractWorkflow.java:1512)
... 10 more
For what i understand is, there is some issue with the permissions, however how do i need to update this?
Sarathi Chatterjee August 10, 2017
_
Thanos Batagiannis [Adaptavist]
November 25, 2015
Update your user name to match your user key.
Find your user key: your-base-url/rest/api/2/myself
Edit your user name: Users -> User management -> Select the user and edit.
JamieA
November 25, 2015
Note: this is a bug, which will be fixed very soon.
Has this been fixed ?
August 10, 2017
Hi Sarathi
Yes it is fixed in version 4.2.0.2
regards,
Thanos
We get this on 4.3.18
Installing 5.0.14 now
Error we get is
017-08-10 15:57:58,084 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2017-08-10 15:57:58,085 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: ITSD-98, actionId: 1, file: <inline script>
com.atlassian.jira.exception.CreateException: An unknown exception occured executing Validator com.atlassian.jira.workflow.SkippableValidator@2232fbbc: root cause: java.lang.NullPointerException
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:588)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:494)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssueObject(DefaultIssueManager.java:599)
at com.atlassian.jira.issue.managers.RequestCachingIssueManager.createIssueObject(RequestCachingIssueManager.java:198)
at Script211.createSubtask(Script211.groovy:64)
at Script211$_run_closure2.doCall(Script211.groovy:23)
at Script211.run(Script211.groovy:22)
Caused by: com.atlassian.jira.workflow.WorkflowException: An unknown exception occured executing Validator com.atlassian.jira.workflow.SkippableValidator@2232fbbc: root cause: java.lang.NullPointerException
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:760)
at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:580)
... 7 more
Caused by: com.opensymphony.workflow.WorkflowException: An unknown exception occured executing Validator com.atlassian.jira.workflow.SkippableValidator@2232fbbc: root cause: java.lang.NullPointerException
at com.opensymphony.workflow.AbstractWorkflow.verifyInputs(AbstractWorkflow.java:1477)
at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1167)
at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:606)
at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:741)
... 8 more
at com.atlassian.jira.workflow.validator.AbstractPermissionValidator.hasUserPermission(AbstractPermissionValidator.java:38)
at com.atlassian.jira.workflow.validator.PermissionValidator.validate(PermissionValidator.java:37)
at com.atlassian.jira.workflow.SkippableValidator.validate(SkippableValidator.java:45)
at com.opensymphony.workflow.AbstractWorkflow.verifyInputs(AbstractWorkflow.java:1466)
... 11 more
Cancel
And the code in use on the POST Function on Create is
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def parentIssue = issue as MutableIssue
if (parentIssue.isSubTask()) {
//the issue in transition is a subtask therefore do nothing
return
def parentSummary = parentIssue.summary
// use http://docs.oracle.com/javase/tutorial/essential/regex/bounds.html because we want to match the exact word
if (parentSummary.matches(".*\\bOFFICE\\b.*")) {
['Create OFFICE Account', 'Create AD Account', 'Create Exchange Account'].eachWithIndex { it, idx ->
createSubtask(parentIssue, it, "Subtask $idx")
else if (parentSummary.matches(".*\\bOFFICE_2\\b.*")) {
['Create OFFICE_2 Account', 'Create AD_2 Account', 'Create Exchange Account_2'].eachWithIndex { it, idx ->
// follow the same pattern for other cases ....
* Create an issue of issue type subtask, for the given parent issue and a text to concat in the parent issue's one
* in order to create the subtask's description.
* All the other required fields are inherited from the parent issue
* @param parentIssue The parent issue which is in transition
* @param description The text to concat to the parent's one in order to create the subtask's description
def createSubtask (MutableIssue parentIssue, String description, String subtaskSummary) {
def subtaskDescription = "$description ${parentIssue.summary}"
// if there is a subtask with the exact description already then do nothing
if (subtaskAlreadyExist(parentIssue, subtaskDescription)) {
log.info "A subtask with description $subtaskDescription already exists, I will NOT create a new one"
return
def issueFactory = ComponentAccessor.getIssueFactory()
def constantManager = ComponentAccessor.getConstantsManager()
def issueManager = ComponentAccessor.getIssueManager()
def subTaskManager = ComponentAccessor.getSubTaskManager()
def newSubTask = issueFactory.getIssue()
newSubTask.setSummary('HELLO')
newSubTask.setDescription(subtaskDescription)
newSubTask.setParentObject(parentIssue)
newSubTask.setProjectObject(parentIssue.projectObject)
newSubTask.setPriority(parentIssue.priority)
newSubTask.setIssueTypeId(constantManager.getAllIssueTypeObjects().find{
it.getName() == "Sub-task"
}.id)
// Add any other fields you want for the newly created sub task see
// https://docs.atlassian.com/jira/7.3.5/com/atlassian/jira/issue/MutableIssue.html
def newIssueParams = ["issue" : newSubTask] as Map<String,Object>
issueManager.createIssueObject(user, newIssueParams)
subTaskManager.createSubTaskIssueLink(parentIssue, newSubTask, user)
log.info "Subtask with summary ${newSubTask.summary} created"
def subtaskAlreadyExist (MutableIssue parentIssue, String subtaskDescription) {
parentIssue.subTaskObjects?.find { it.description == subtaskDescription }
August 10, 2017
Can you try to replace the
with a user that has for sure Create Issue Permissions for this project ?
Something like
def user = ComponentAccessor.getUserManager().getUserByKey("admin")
let me know how this goes.
Marcel J. Wüstner November 19, 2015
Additionally i have the following error when running the Scriptrunner Script registry
For the code:
issue.summary = sourceIssue.summary + ' - TEST'
[Static type checking] - The variable [sourceIssue] is undeclared. @ line 1, column 17.
[Static type checking] - Cannot find matching method java.lang.Object#plus(java.lang.String). Please check if the declared type is right and if the method exists.
Possible solutions: is(java.lang.Object), split(groovy.lang.Closure), use([Ljava.lang.Object;), use(java.lang.Class, groovy.lang.Closure), wait(), grep() @ line 1, column 37.
November 20, 2015
This is a STC (static type checking) issue, but it doesn't make your action to fail.
Marcel J. Wüstner November 20, 2015
okay thank you. i am just trying to find anything which could give us an indication where teh problem is. Because of the failing script i have already half a project team not able to work in their used workflow which gives us a lot of overhead currently.
November 20, 2015
Marcel could you please raise a support ticket here: https://productsupport.adaptavist.com/servicedesk/customer/portal/2, so we can continue the troubleshooting from there ? Thanks
I ran also the test-run from script runner built in scripts got the following errors, not sure if this helps
Run5
Failures8
Errortest script with workflow transitions(com.acme.scriptrunner.test.TestAddComponentLeadsAsWatchers)
org.spockframework.runtime.ConditionNotSatisfiedError:
Condition not satisfied:
createValidationResult.isValid()
|                      false
com.atlassian.jira.bc.issue.IssueService$CreateValidationResult@2065720
|                      false
com.atlassian.jira.bc.issue.IssueService$CreateValidationResult@51099a38
|                      false
com.atlassian.jira.bc.issue.IssueService$CreateValidationResult@26c0aa30
Errortest due date script field(com.acme.scriptrunner.test.TestVersionDueDateScriptedField)
|                      false
com.atlassian.jira.bc.issue.IssueService$CreateValidationResult@5e61946d
|                      false
com.atlassian.jira.bc.issue.IssueService$CreateValidationResult@57d243ed
|                      false
com.atlassian.jira.bc.issue.IssueService$CreateValidationResult@173162c4
|                      false
com.atlassian.jira.bc.issue.IssueService$CreateValidationResult@21997723
|                      false
com.atlassian.jira.bc.issue.IssueService$CreateValidationResult@f1fc445
hi Thanos, i have admin-rights and i can also create tickets and subtickets manually but the workflow post function seems not to work.
November 19, 2015
Hi Marcel, I tested in my local instance (JIRA7, SR-4.2), no problem appeared. As you mentioned there is something wrong with the user. Does this user has permission to create issues ?
Roy Chapman
I had the same issue.  Turns out that the option to create sub task as user was failing.  This was a test project and the user selected had no permissions to create the sub task.
That's right, i am only using the built-in "Create subtask" script
JamieA
November 18, 2015
Hi @Thanos Batagiannis [Adaptavist] , it's the built-in "Create subtask" script, he said he wasn't using any additional code.
November 18, 2015
Hi Marcel, Would you like to post the script you use for your post function (a couple of API changes happened in JIRA7) ?
