Create branch trigger bypasses post function custom script using ScriptRunner
Anj Willnecker July 28, 2017 edited
Transition: Start Progress
Added JIRA trigger
Branch created
Automatically transitions the issue when a related branch is created in a connected repository
Post Function  (note that it always shows success but assignee field remains unchnaged when create branch; only works in normal JIRA transition)
// Get the current user
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def Issue issue = issue
if (currentUser != issue.assignee) {
issue.assignee = currentUser
Jobin Kuruvilla [Adaptavist]
July 30, 2017
That is how they are designed. Triggers bypasses validators. See https://confluence.atlassian.com/adminjiraserver074/configuring-workflow-triggers-881683835.html
July 30, 2017
When a transition is triggered automatically, it ignores any conditions, validators or permissions configured on the transition.
Anj Willnecker July 31, 2017 edited
Post function should still execute.   How does the transition tab know who the user is but the post function either doesn't know or doesn't execute?
