Create branch trigger bypasses post function custom script using ScriptRunner and validator
Anj Willnecker July 28, 2017
custom ScriptRunner post function on transition Start Progress shows as successful but only updates Assignee field during normal JIRA transition.  When create branch trigger executes the assingee value remains unassigned (not changing) and validator Required fields: Acceptance Criteria is also bypassed.
// Get the current user
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def Issue issue = issue
if (currentUser != issue.assignee) {
issue.assignee = currentUser
Anj Willnecker August 9, 2017 edited
Aidan Derossett [Adaptavist]
August 9, 2017
Hey Anj!
So this is just a hunch at this point, but it may be that your script is being executed, but the changed asignee isn't being persisted to the JIRA database. Could you go ahead and try this code? I've made a couple of edits to ensure that the changes are indexed:
def issueManager = ComponentAccessor.issueManager
//Persist the assignee change to the DB
issueManager.updateIssue(currentUser, issue, EventDispatchOption.DO_NOT_DISPATCH, false)
 Try that script out and let me know what you find! :)
If it doesn't change anything, we may have to look a little further into the problem.
-Aidan
Hello, Aidan.  I tried the code and the record remained unassigned when I create branch but auto assigns during normal JIRA worfklow.  Thanks for trying though.
