Fast-track transition an issue : How to Fast-track when value is < 250
Fabian van den Barselaar
I have a (custom) field "Amount" - ID : 12704  (number field)
I want to check on create, when value is less or equal to 250, fast-track to the next status.
I tried:
cfValues['12704'] <= 250
and :
parseInt(cfValues['12704']) <= 250
But no success unfortunate...
Who can help?
Sander Brienen [Avisi]
June 10, 2015
the Amount custom field appeared to be a Number and therefore returns a Double.
Comparing a Double in this I solved by this line of code:
cfValues['Amount'] &lt; Double.valueOf(250)
JamieA
June 9, 2015
Maybe:
cfValues['12704'] as Integer <= 250
Too bad, didn't do the trick
JamieA
June 9, 2015
Sorry, it should be: cfValues['Name of custom field'] as Integer < 999
I tried: cfValues['Amount'] as Integer < 999 cfValues['12704'] as Integer < 999 cfValues['Amount'] as Integer < 250 cfValues['12704'] as Integer < 250 but none of them triggers it :(
JamieA
June 9, 2015
the first and third are the same right...? If that is the field name, and assuming it doesn't have any trailing whitespace (check) it should work. Have you checked the log for errors?
SMAtlassianMber
Wondering if anyone got this to work. I'm getting the following error for cfValues['One Time Cost'] as Integer < 11000
The script could not be compiled: <pre>org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script97.groovy: 1: expecting EOF, found '(' @ line 1, column 37. cfValues['One Time Cost'] as Integer < 11000 ^ 1 error </pre>.
