Help setting User Property dynamically using a groovy script
Blake Jones June 23, 2017
We have 289 users currently, and have been told that for integration purposes we need to now create a User Property for each of them that holds their email alias without the @domain.com piece due to special character issues. Rather than have to update all 289 of them manually one by one, I'm hoping to script something up.
This is what I've gotten so far based on what I've found in forums and online. I believe my issue is related to the fact that I'm not getting an ApplicationUser as I iterate through the userList collection, and then I have an error on the getPropertySet() that I can't decipher.
import com.atlassian.jira.user.util.UserUtil
import com.atlassian.jira.user.util.UserManager
UserUtil userUtil = ComponentAccessor.getUserUtil()
def userPropertyManager = ComponentAccessor.getUserPropertyManager()
def userManager = ComponentAccessor.getUserManager()
def userList=[UserManager.getAllApplicationUsers()]
def email
userList.each { thisUser ->
    email = thisUser.getEmailAddress()
    userPropertyManager.getPropertySet(thisUser.getName()).setString("jira.meta.Alias",email.substring(0, email.indexOf('@')))
and the error message:
2017-06-23 17:33:36,795 WARN [common.UserScriptEndpoint]: Script console script failed:
groovy.lang.MissingMethodException: No signature of method: static com.atlassian.jira.user.util.UserManager.getAllApplicationUsers() is applicable for argument types: () values: []
	at Script80.run(Script80.groovy:8)
Daniel Yelamos [Adaptavist]
June 26, 2017
Hi Blake.
I think you should do this:
def userList=UserManager.getAllApplicationUsers()
def email
 Without the brackets around the user manager, the script will give you a red at the start of the closure, but in execution time it should work properly. If you want to avoid the red you could do this:
Collection<ApplicationUser> userList=UserManager.getAllApplicationUsers()
def email
Hope this helps!
Cheers!
Dyelamos
Blake Jones June 26, 2017
Thanks Dyelamos! I've tried both methods, but unfortunately am still getting the same error (for both methods):
Logs:
2017-06-26 10:32:40,572 WARN [common.UserScriptEndpoint]: Script console script failed:
 at Script95.run(Script95.groovy:8)
Result:
June 27, 2017
Oh boy :D
I just realised, that you are calling
UserManager, (first letter is a capital, which is a global variable)
insted of
userManager, (first letter undercase) which is the variable you get line 3.
Apologies for missing that. Your script should look like this:
def userList=userManager.getAllApplicationUsers()
def email
Cheers!
Dyelamos
Blake Jones June 27, 2017
Thanks Dyelamos - that would have driven me crazy!
I was able to finally get it to work with your script by changing
 to
userPropertyManager.getPropertySet(thisUser)
thanks again for your help!
June 27, 2017
No problem. Please accept my answer so that people know this has been answered!
Cheers
Dyelamos
Jarrod
Thanks @Daniel Yelamos [Adaptavist]
This helped me.
I think though that there've been some changes since you submitted that code, so here is the latest code that I used.  However, my requirement was to remove the users "autowatch" preferences and let it inherit the settings:
def userList= userUtil.getUsers() //UserManager.getAllApplicationUsers()
def email
def username
def propertySet = userPropertyManager.getPropertySet(thisUser)
propertySet.remove("user.autowatch.disabled")
