Hi community I need some help with a basic formula for a structure I created.
I need the formula to pull information from a ticket(s) in the structure, like this (These fields are being extracted from certain fields in the tickets):
Field 1 (K) = 1
Field 2 (P) = 4
Field 3 (O) = 3
The formula would add P+K together (well call this sum A), and then do the following calculation: K x A x O = ____
Can anyone please help me out with this?
Thank you!
Hi Ryan,
This is actually rather simple with formula columns in Structure. This code should do what you describe.
WITH A = P + K :
K * A * O
The formula will ask you to define what K,P, and O are, but you can easily point them to issue fields. The reason we don't need to define A is because it is set by the WITH statement in the first line. The second line simply returns the result of the multiplication, this is what will be displayed in the column.
Nick [ALM Works]
