Hide sidebar item Terms of Smart Terms in spaces where it in not used
Horst Weinhold
March 30, 2022
I've set in the global Smart Terms configuration unter Permissions to restrict terms creation to a few spaces. But on all the other spaces the item Terms appears in the sidebar.
Is it possible to hide the sidebar item Terms of Smart Terms in all spaces by default?
Salma Sahnoun_Creativas_
Hi Horst,
You can hide the "Terms" app from the sidebar per space. This is not done by default.
Click on Space tools and choose configure sidebar.
Click on "hide link" in front of the targeted app, and you are done.
I hope this helps.
If you need any further assistance with Smart Terms, you can reach out to the support team. They will be glad to help.
Horst Weinhold
April 4, 2022
Hi Salma,
If you have some spaces but want to use the plugin only in certain spaces, it may take some work.
But thanks for your answer, it helps.
