Maybe you can try this?
issue.getComponentObjects().getAt(
0
)?.getName()
Best Regards,
Mirek
Hi Mirek,
I tried this snippet too. Syntax check was successful, but output was blank.
@Mirek , I tried your solution, it is working but it is only showing output for the very first component value, not all the values present in component.
Suppose I have components = a,b,c
so when I execute issue.getComponentObjects().getAt(
0
)?.getName()
the output is a
Is there any way so that we can pull all the component values?
Try simply
issue.components.name
Hi Gezium, thanks for the snippet, but this didn't help me.
Where are you running it.
I just tried in script console (JIRA 7.3) and worked.
Maybe you are running it on a post function?
I am trying in JIRA 7.2.2 Scriptrunner, i want to fetch value which is present in Component/s and display in scripted field.
Ok, I added it in a scripted field, it originally shows a typing validation error, but bypassing and saving works.
Even just by preview it shows the component/s, Also in screen it's shown as a list []
Can you please share the whole code in here??
it's just that line.
@Gezim Shehu [Communardo] this works for me.
I am trying this in script console , it is giving a red mark but in output it is giving me all component values
Thx mate - it is as simple :-)
// Console
def componentField = Issues.getByKey('KEY-123').components.name
// Shows a list of all Components
// I can now check if my component is part with
componentField.contains("My Value")
// Output "true" when Component is part of the ticket
