I would like to calculate issue resolution time per each assignee involved and display it report where rows have assignees and columns have months.
I created a custom field "Time per assignee" and added Javascript code to calculate measure values :
[jira.customfield_time_per_assignee]
name = "Time per assignee"
data_type = "decimal"
measure = true
multiple_dimensions = ["Time","Assignee"]
javascript_code = '''
var divider = 1000 * 60 * 60;
var assigneehistory = new Array();
var datefrom = issue.fields.created;
var assignee = "unassigned";
var assigneeItem = null;
var resolutionItem = null;
var resolution = null;
var resolutionDate = null;
issue.changelog.histories.forEach(function(history)
dateto = history.created;
history.items.forEach(function(historyItem)
if (historyItem.field == "assignee") {
assigneeItem = historyItem;
else if (historyItem.field == "resolution") {
resolutionItem = historyItem;
if (assigneeItem)
if ((!resolutionItem || resolutionItem.to) && !resolution)
assignee = assigneeItem.from ? assigneeItem.from : "unassigned";
duration = (Date.parse(dateto) - Date.parse(datefrom)) / divider;
assigneehistory.push(assignee + "," + duration);
datefrom = dateto;
assignee = assigneeItem.to ? assigneeItem.to : "unassigned";
if (resolutionItem)
if (!assigneeItem)
if (resolutionItem.to && !resolution)
datefrom = dateto;
resolution = resolutionItem ? resolutionItem.to : null;
resolutionDate = dateto;
for(i = 0; i < assigneehistory.length; i++) {
assigneehistory[i] = resolutionDate.toString().substr(0,10) + "," + assigneehistory[i];
issue.fields.customfield_time_per_assignee = assigneehistory.join("\n");
This woks when issue has assignee, but unfortunately, my issues doesn't... Adding custom field something like "Resolved by" and using it instead of Assignee (multiple_dimensions = ["Time","Resolved by"]) doesn't help, because the cube import throws an error telling that "Resolved by" cannot be used in multiple dimensions...
How could i solve this ? Is there an esier way to calculate how much time some user was the assignee of an issue?
