Hi
I am trying to create an Automation Scheduled rule which will run Groovy Script without running JQL.
In Script Console I can checl that all working ok and all log.warn() messages are printed out in log to trace various stages.
Once I copied same script to Automation Stage it does not run anything if I don't specify a JQL search which I don't need as I will do all in script.
Do I miss something?
Shall i assume that thare are some limitations for ScriptRunner task in Automation?
Choice "simply run the conditions and actions without providing issues" on https://docs.automationforjira.com/getting-started/triggers.html#scheduled
Areg
Ref: https://scriptrunner.adaptavist.com/latest/jira/plugins/automation-for-jira.html
Hi Areg,
I believe there's a bug on the ScriptRunner side, where if there is no issues returned then we don't run your script: https://productsupport.adaptavist.com/browse/SRJIRA-3302
Are you just using the rule for scheduling purposes? If so I'd suggest using a _Service_, which will let you run a script on a schedule: https://scriptrunner.adaptavist.com/latest/jira/services.html
Many people also use _escalation services_ for something similar: https://scriptrunner.adaptavist.com/latest/jira/escalation-service.html
cheers, jamie
Thanks Jamie
Sorry I can't accept answer as this is reported from my wrong account which is not accessible now.
Areg
No problem, I'm over getting rep on here ;-)
Hi Jamie
I have tried Escalation Service but for some reason simple JQL {{project = PRJ}} which has results in issue search reports 0 issues in the Escalation Service when I try to manually run it.
Is there a trick to run Escalation Services?
Areg
Right - user issue ( https://community.atlassian.com/t5/Marketplace-Apps-questions/JQL-never-return-any-issues-in-Escalation-Service-Scriptrunner/qaq-p/737189 )
Looks like again, I can't set up to run it with no JQL.
So as same as in Automation I need to invent some kind of Issue and JQL which will always have 1 result output to run this only 1 time.
If you just need a scheduler, then it's best to use a Service... I pointed to the doc in my original message.
