How to enforce naming conventions using ScriptRunner add-on with Bitbucket
Mary Slocum July 2, 2018
Using ScriptRunner add-on 5.1.8 with Bitbucket 5.3.2, is there a way to enforce naming conventions for projects and repos? If so, how?
I see that there is enforcing naming conventions for feature and bugfix branches using the Pre-receive Hooks, but is there anything for project and repo names?
Mary
adammarkham
July 4, 2018
You could do that using a custom event handler.
For example you can use the following script for the ProjectCreationRequestedEvent. You'll need to change the regex part. At the moment it enforces that project keys must begin with a C followed by at least one upper case character in A-Z.
def regex = "C[A-Z]+"
if (! (event.project.key ==~ /${regex}/)) {
event.cancel("Project key must start with C!")
Let us know how that goes.
Mary Slocum July 4, 2018
Works great! Thank you so much for your help :)
Mary
adammarkham
July 3, 2018
Hi Mary,
There is an event handler for that using ScriptRunner. It's called "Naming standard enforcement" with the description "Enforce project and repository naming standards".
The documentation can be found here but it's works similarly to the branch and tag naming convention one.
Let us know how you get on.
Adam
Mary Slocum July 3, 2018
Thanks, Adam!
I was on an older version, so I didn't see that available.
But, is there a way to enforce a naming convention for the Project Key? I'm now fine with the Project Name being descriptive, but I need to enforce a naming convention on the Project Key.
Mary
atlassian, social impact bingo, may it forward, atlassian foundation, community engagement, atlassian community events, atlassian learning, social impact challenge, volunteering, community kudos, atlassian social impact, atlassian community
Come one, come all!
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻‍♂️
