I am looking for a way to limit the range of a number field to a certain range of natural numbers. This should always apply and not only in a certain workflow step. I tried to add Javascript to the description as described here. But I guess I am lacking of some important details.
I thought of using Behaviors provided by Script Runner but also lacking of the implementation details. Perhaps someone has some hints or even a detailed description of how to do it.
Michaela
You need to create a behavour. In the field part of the behavour add your customfield. Then push create serverside script button. I am not sure that I understand correctly your required condition but the script will be like the following:
def cs = getFieldByName("CustomFieldNAme")
if (cs.getValue().toString().length() < 2) {
cs.setError("Hello error")
cs.setRequired(true)
} else {
cs.setError("")
cs.setRequired(false)
You can read more about behavours here:
https://scriptrunner.adaptavist.com/4.3.1/jira/behaviours-overview.html#_description
