×Hello,
I am not able to use that tool according its documentation.
"The Insight Discovery Collector is a tool that allows you to run multiple instances of Discovery in parallel and integrate those results into one data set."
I have tried several times to make that collector working but it doesnt repack the data.. it only transfers the zip files (from different discovery tool scans) from the input directory to the output directory without merging them. Are there any conditions for that action?
I tried using the service instead manual run but the result is the same. In the configuration of the tool I couldn't find anything useful in that direction.
Hi Stiliyan,
It seems this functionality has been removed. Please, see below:
related:
Have you run into the below?
Hello Stiliyan,
I made the same mistake than you. Discovery is not an installable app, you have to extract the folder in the local disk an execute discovery -s in cmd to configure. Don't install Discovery_Agent, it's not the main application, it's only a remote agent to connect networks with the main discovery app.
regards.
