Hello ,
I am a ITAdmin in my organization, we want to have this feature in our cloud JIRA platform, but "Watcher Custom Field for JIRA " is not supporting in cloud JIRA.
Is it possible to provide this plug-in in Cloud platform also?
Thanks & Regards,
-Sidd
You've answered your own question. It's not supported.
I don't know if the vendor is planning a conversion. From my understanding of the structure of Cloud, it's not possible to add such a field as a Connect add-on, so it's not possible directly, but I suspect that you could write something that would do roughly the same thing with a normal user-picker field and a couple of Connect listeners to update it.
Atlassian Connect has recently added basic support for custom fields for Atlassian Connect add-ons: https://developer.atlassian.com/static/connect/docs/latest/modules/jira/issue-field.html
I don't think that it yet supports user pickers but the Add-on developer should be able to build most of their functionality using Atlassian Connect (if not all of it).
@Siddesh S V you should reach out and contact the add-on vendor directly to make this request.
