Is there a way to Clone and link issue using Custom script post function instead of "Clone and link" built in script
Thanks.
You could clone an issue with IssueFactory.cloneIssueWithAllFields(issue). The function would return the new issue. Then you could create a link with IssueLinkManager.createIssueLink
Hi Alexey,
Thanks for the reply.
The Jira version I use is 6.4.14, the method IssueFactory.cloneIssueWithAllFields(issue) doesn't exist for this version.
https://docs.atlassian.com/software/jira/docs/api/6.4.14/com/atlassian/jira/issue/IssueFactory.html
Since the cloneIssueWithAllFields doesn't exist, do we have to copy all the fields manually?
Thanks.
Yes, You need to copy required fields by yourself. You can find more info here:
https://developer.atlassian.com/server/jira/platform/performing-issue-operations/
