I would like to allow specific users to see specific issue types in a project only, not all available issue types. It seems that it is not possible to do that directly in the permissions scheme. Any ideas?
No, but yes.
You can't do it directly, as issue permissions are done at a project level. (Although there are some project level things I'd like to see done at an issue level, security is not really one of them)
The "but yes" is because you can do it indirectly.
Give your users permission to see the project as normal. Then create an issue security scheme. An issue security scheme allows you to set a "level" on individual issues that can restrict it to certain users.
Now, that's not "by issue type". Your users can set the levels on any issue they want. But. You *can* set the security level in the workflow, and have different workflows by issue type.
So you can have a workflow that sets the security level to "secret squirrel" on create, and second one that does not set anything. Then make "Bug" follow the "secret squirrel" and "Question" follow the open one.
Neither. You're changing data, so you do it in a post-function.
