JJUPIN will not enable
jim blizzard December 6, 2013
Start up log
2013-12-06 17:05:18,977 localhost-startStop-1 INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from D:\Program Files\Atlassian\Application Data\JIRA525_Home_Dir\dbconfig.xml
2013-12-06 17:05:19,539 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
JIRA starting...
2013-12-06 17:05:19,554 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Environment _____________________________
JIRA Build : 5.2.5#847-sha1:7fd7dd6f72035074370cfd27de760a25c1261256
Build Date : Mon Jan 14 00:00:00 EST 2013
JIRA Installation Type : Standalone
Application Server : Apache Tomcat/7.0.29 - Servlet API 3.0
Java Version : 1.6.0_35 - Sun Microsystems Inc.
Current Working Directory : D:\Program Files\Atlassian\JIRA525_Install_Dir\bin
Maximum Allowable Memory : 1979MB
Total Memory : 247MB
Free Memory : 228MB
Used Memory : 19MB
Memory Pool: Code Cache : Code Cache: init = 2555904(2496K) used = 1779904(1738K) committed = 2555904(2496K) max = 50331648(49152K)
Memory Pool: Eden Space : Eden Space: init = 71630848(69952K) used = 14408376(14070K) committed = 71630848(69952K) max = 572653568(559232K)
Memory Pool: Survivor Space : Survivor Space: init = 8912896(8704K) used = 1609744(1572K) committed = 8912896(8704K) max = 71565312(69888K)
Memory Pool: Tenured Gen : Tenured Gen: init = 178978816(174784K) used = 4101224(4005K) committed = 178978816(174784K) max = 1431699456(1398144K)
Memory Pool: Perm Gen : Perm Gen: init = 21757952(21248K) used = 20567504(20085K) committed = 21757952(21248K) max = 536870912(524288K)
JVM Input Arguments : -Dcatalina.base=D:\Program Files\Atlassian\JIRA525_Install_Dir -Dcatalina.home=D:\Program Files\Atlassian\JIRA525_Install_Dir -Djava.endorsed.dirs=D:\Program Files\Atlassian\JIRA525_Install_Dir\endorsed -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dmail.mime.decodeparameters=true -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Djava.io.tmpdir=D:\Program Files\Atlassian\JIRA525_Install_Dir\temp -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.util.logging.config.file=D:\Program Files\Atlassian\JIRA525_Install_Dir\conf\logging.properties -XX:MaxPermSize=512m -Xms256m -Xmx2048m
___ Java System Properties ________________
atlassian.standalone : JIRA
awt.toolkit : sun.awt.windows.WToolkit
catalina.base : D:\Program Files\Atlassian\JIRA525_Install_Dir
catalina.home : D:\Program Files\Atlassian\JIRA525_Install_Dir
catalina.useNaming : true
common.loader : ${catalina.base}/lib,
${catalina.base}/lib/*.jar,
${catalina.home}/lib,
${catalina.home}/lib/*.jar
file.encoding : Cp1252
file.encoding.pkg : sun.io
java.awt.graphicsenv : sun.awt.Win32GraphicsEnvironment
java.awt.headless : true
java.awt.printerjob : sun.awt.windows.WPrinterJob
java.class.version : 50.0
java.home : D:\PROGRA~2\ATLASS~1\JIRA52~1\jre
java.io.tmpdir : D:\Program Files\Atlassian\JIRA525_Install_Dir\temp
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.runtime.name : Java(TM) SE Runtime Environment
java.runtime.version : 1.6.0_35-b10
java.specification.name : Java Platform API Specification
java.specification.vendor : Sun Microsystems Inc.
java.specification.version : 1.6
java.util.logging.config.file : D:\Program Files\Atlassian\JIRA525_Install_Dir\conf\logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : Sun Microsystems Inc.
java.vendor.url : http://java.sun.com/<br< a="">> java.vendor.url.bug : http://java.sun.com/cgi-bin/bugreport.cgi<br< a="">> java.version : 1.6.0_35
java.vm.info : mixed mode
java.vm.name : Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Sun Microsystems Inc.
java.vm.specification.version : 1.0
java.vm.vendor ...
http://confluence.atlassian.com/x/1xy6D
2013-12-06
17:07:53,814 localhost-startStop-1 WARN [plugin.osgi.factory.OsgiPlugin] Unable to enable plugin 'com.keplerrominfo.jira.plugins.jjupin'
com.atlassian.plugin.osgi.container.OsgiContainerException: Cannot start plugin: com.keplerrominfo.jira.plugins.jjupin
at com.atlassian.plugin.osgi.factory.OsgiPlugin.enableInternal(OsgiPlugin.java:445)
at com.atlassian.plugin.impl.AbstractPlugin.enable(AbstractPlugin.java:237)
at com.atlassian.plugin.manager.PluginEnabler.actualEnable(PluginEnabler.java:114)
at com.atlassian.plugin.manager.PluginEnabler.enable(PluginEnabler.java:99)
at com.atlassian.plugin.manager.DefaultPluginManager.addPlugins(DefaultPluginManager.java:725)
at com.atlassian.plugin.manager.DefaultPluginManager.init(DefaultPluginManager.java:178)
at com.atlassian.jira.plugin.JiraPluginManager.start(JiraPluginManager.java:58)
at com.atlassian.jira.ComponentManager$PluginSystem.start(ComponentManager.java:671)
at com.atlassian.jira.ComponentManager.startJIRA(ComponentManager.java:220)
at com.atlassian.jira.ComponentManager.quickStart(ComponentManager.java:212)
at com.atlassian.jira.ComponentManager.start(ComponentManager.java:197)
at com.atlassian.jira.upgrade.PluginSystemLauncher.start(PluginSystemLauncher.java:23)
at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:105)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:284)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:169)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:98)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:25)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:64)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:59)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:80)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:75)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:108) <+5> (StandardContext.java:4791) (StandardContext.java:5285) (LifecycleBase.java:150) (ContainerBase.java:1559) (ContainerBase.java:1549)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.osgi.framework.BundleException: Unresolved constraint in bundle com.keplerrominfo.jira.plugins.jjupin [130]: Unable to resolve 130.0: missing requirement [130.0] package; (&(package=com.keplerrominfo.jira.commons.jira.kconfig)(version>=2.6.0)(!(version>=3.0.0)))
at org.apache.felix.framework.Felix.resolveBundle(Felix.java:3409)
at org.apache.felix.framework.Felix.startBundle(Felix.java:1709)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:905)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:892)
at com.atlassian.plugin.osgi.factory.OsgiPlugin.enableInternal(OsgiPlugin.java:417)
2013-12-06 17:07:53,814 localhost-startStop-1 ERROR [atlassian.plugin.manager.PluginEnabler] Unable to enable plugin com.keplerrominfo.jira.plugins.jjupin
2013-12-06 17:07:53,845 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Name is Microsoft SQL Server
2013-12-06 17:07:53,845 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Version is 10.00.5500
2013-12-06 17:07:53,845 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Name is jTDS Type 4 JDBC Driver for MS SQL Server and Sybase
2013-12-06 17:07:53,845 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Version is 1.2.4
2013-12-06 17:07:54,376 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Name is Microsoft SQL Server
2013-12-06 17:07:54,376 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Product Version is 10.00.5500
2013-12-06 17:07:54,376 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Name is jTDS Type 4 JDBC Driver for MS SQL Server and Sybase
2013-12-06 17:07:54,376 localhost-startStop-1 INFO [core.entity.jdbc.DatabaseUtil] Database Driver Version is 1.2.4
2013-12-06 17:07:54,501 Spring executor 19 WARN [sf.ehcache.config.ConfigurationFactory] No configuration found. Configuring ehcache from ehcache-failsafe.xml found in the classpath: bundle://126.0:4/ehcache-failsafe.xml
2013-12-06 17:07:55,015 localhost-startStop-1 ERROR [plugin.osgi.factory.OsgiPlugin] Detected an error (BundleException) enabling the plugin 'com.keplerrominfo.jira.plugins.warden' : Activator start error in bundle com.keplerrominfo.jira.plugins.warden [133].. This error usually occurs when your plugin imports a package from another bundle with a specific version constraint and either the bundle providing that package doesn't meet those version constraints, or there is no bundle available that provides the specified package. For more details on how to fix this, see http://confluence.atlassian.com/x/1xy6D
2013-12-06
17:07:55,015 localhost-startStop-1 WARN [plugin.osgi.factory.OsgiPlugin] Unable to enable plugin 'com.keplerrominfo.jira.plugins.warden'
com.atlassian.plugin.osgi.container.OsgiContainerException: Cannot start plugin: com.keplerrominfo.jira.plugins.warden
Caused by: org.osgi.framework.BundleException: Activator start error in bundle com.keplerrominfo.jira.plugins.warden [133].
at org.apache.felix.framework.Felix.activateBundle(Felix.java:1864)
at org.apache.felix.framework.Felix.startBundle(Felix.java:1734)
Caused by: java.lang.NoClassDefFoundError: com/keplerrominfo/jira/commons/jira/kconfig/AbstractPluginLifecycleActivator
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.findClass(ModuleImpl.java:1829)
at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:716)
at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.loadClass(ModuleImpl.java:1690)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.apache.felix.framework.ModuleImpl.getClassByDelegation(ModuleImpl.java:634)
at org.apache.felix.framework.Felix.createBundleActivator(Felix.java:3653)
at org.apache.felix.framework.Felix.activateBundle(Felix.java:1812)
... 43 more
Caused by: java.lang.ClassNotFoundException: com.keplerrominfo.jira.commons.jira.kconfig.AbstractPluginLifecycleActivator
at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:772)
at org.apache.felix.framework.ModuleImpl.access$200(ModuleImpl.java:73)
... 54 more
2013-12-06 17:07:55,015 localhost-startStop-1 ERROR [atlassian.plugin.manager.PluginEnabler] Unable to enable plugin com.keplerrominfo.jira.plugins.warden
... 43 more
... 54 more
2013-12-06 17:08:01,786 localhost-startStop-1 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [plugin.jviz, jira.plugin.projectspecificselectfield.jpssf, worklog.worklog-Report, net.customware.jira.plugins.createandlink, com.pyxis.greenhopper.jira, net.customware.jira.plugins.mdsf, com.xpandit.plugins.jiraxporter, ru.mail.jira.plugins.mailrucal], 60 seconds remaining
Silviu Burcea
December 7, 2013
You have JIRA 5.2.5 but you probably tried to install JJupin 2.6.x for JIRA 6. Uninstall it(including katl-commons and warden) and install JJupin 2.5.x for JIRA 5.
HTH
Florin Manaila
December 8, 2013
Carlos Gucci
May 27, 2024
I've recently discovered a fantastic online gaming world https://betvisa-apk.com/customer-service/ right here in Bangladesh. The user-friendly interface of the platform is second to none, making it incredibly easy to navigate through the exciting games. The vibrant energy and diverse game selection instantly transport you into a whirlwind of fun and excitement! For anyone looking for a thrilling experience, I can't recommend enough to click on this link and dive right in. It's an experience you really don't want to miss out on!
