JQL to find issues with same Fix Version name as current issue, not ID
Jeremy Cupps February 21, 2019
I would like to use JQL to show all issues with the same Fix Version name as the current issue, not id. The reason for this is that we keep test cases in a separate project from our features and bugs which has the same version names but obviously the ids are different.
According to the documentation, currentIssue.fixVersion returns the ids of all Fix Versions for the current issue: https://botronsoft.atlassian.net/wiki/spaces/ILV/pages/113246226/JQL+extension+for+system+fields#JQLextensionforsystemfields-Fixversion
Is there any way to achieve this? Thanks
Alex Koxaras _Relational_
October 9, 2021
Hi @Jeremy Cupps
Did you contact vendor's support? Most likely they will be able to help you with that!
