Jira Issue creation using REST API in Script Runner
Fabio Manzoni
Hi everyone,
I`m trying to do a test integration of two jira instances using Script Runner.
On first instance the code (see below) during the transaction call an event and this event run the code on listener in scriptrunner.
This code its ok with green symbol and run. But anything  happend. I knew that this is a simple test,  but I don`t know what is my mistake.
Can someone help me ?
import groovy.json.StreamingJsonBuilder
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import java.text.SimpleDateFormat
import java.text.DateFormat
import com.atlassian.jira.issue.comments.CommentManager
def baseURL = "http://localhost:8081/rest/api/2/issue";
// localhost:8081 it`s the target instance
def authString = "admin:admin".getBytes().encodeBase64().toString();
def body_req = [
{ "fields":
"project":
"key": "PT"
"summary": "My Issue.",
"description": "Creating of an issue using project keys and issue type names using the REST API",
"issuetype":
"name": "Bug"
URL url = new URL(baseURL);
HttpURLConnection connection=(HttpURLConnection)url.openConnection();
connection.setRequestProperty( "Authorization", "Basic ${authString}" );
connection.requestMethod = "POST";
connection.doOutput = true;
connection.setRequestProperty("Content-Type", "application/json;charset=UTF-8");
connection.outputStream.withWriter("UTF-8") { new StreamingJsonBuilder(it, body_req) }
connection.connect();
Fabio Manzoni
Problem resolved,
I just forget the / after issue.
before
after
def baseURL = "http://localhost:8081/rest/api/2/issue/";
Vineela Durbha
Hi @Fabio Manzoni
I have used your script to create an issue but it is not throwing any error or creating the issue. Can you help me why is it so?
Fabio Manzoni
@Vineela Durbha
You could resolve this.. sorry for delay.
Matthias Gaiser _K15t_
July 18, 2018
Hi Fabio,
I can't tell you the exact solution, but maybe how you can get there. Why don't you integrate some logging into your script as described in the Scriptrunner docs? You could furthermore write a try-catch block around everything beneath your import statements and log the error (or act accordingly).
Having said that, I'd like to ask you what you are accomplishing to do - obviously you want to create an issue on another instance. But what is your further intent? Keeping the two issues in sync?
We are developing an issue sync app: Backbone Issue Sync for Jira.
Backbone allows you to simply create issues in another Jira as well as keeping them in sync afterwards. You can configure in a UI all the data you want to exchange (fields, issue types, workflow states, ...) and don't have to wrestle with groovy scripts.
If you think that is helpful to you, give it a try. And let us know via support@k15t.com if you need a demo or any other help.
Matthias
Fabio Manzoni
Hi Matthias,
Good idea about put logging into my script. The intention its just sync issues in both instances, but buy another app is not an option at this moment.
I'll continue with my tests.
Fabio
July 19, 2018
Fine with me, Fabio.
I simply want to point you to possible solutions which might save you some time. You choose yourself your best option. :)
