Load failed for reason: Too many PermissionScheme schemes found for Project
Roy Chapman
I get this error import project IMOT.  It refers to a different project.  Any ideas?
Load failed for reason: Too many PermissionScheme schemes found for Project VGSORI
[Project IMOT]
INFO 15:15:50,354 Parsing XML file...
INFO 15:15:50,366 Starting to apply project configuration...
INFO 15:15:50,368 Creating project IMOT IMO CoS Activities
WARN 15:15:50,448 Skipping users...
WARN 15:15:50,448 Skipping groups...
WARN 15:15:50,448 Skipping project roles...
INFO 15:15:50,470 [Issue Type Epic] Modifying icon url to: /images/icons/issuetypes/epic.png
INFO 15:15:50,516 [Issue Type Issue] Modifying icon url to: /images/icons/issuetypes/genericissue.png
INFO 15:15:50,529 [Issue Type Story] Modifying icon url to: /images/icons/issuetypes/story.png
INFO 15:15:50,542 [Issue Type Task] Modifying icon url to: /images/icons/issuetypes/task.png
INFO 15:15:50,689 [Custom Field Planning Points] Creating configuration scheme [IMOT]
INFO 15:15:50,770 [Custom Field Planning Points] [Scheme [IMOT]] Creating configuration Default Configuration for Planning Points
INFO 15:15:50,868 [Custom Field Planning Points] [Scheme [IMOT]] Creating association for issue type null to FieldConfig Default Configuration for Planning Points
INFO 15:15:51,056 [Custom Field Cost Object] Creating configuration scheme [IMOT]
INFO 15:15:51,135 [Custom Field Cost Object] [Scheme [IMOT]] Creating configuration Default Configuration for Cost Object
INFO 15:15:51,193 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option 17: Global Regulatory and Accounting Con (CCT-PRJ-00308)
INFO 15:15:51,217 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option 277: TW Consolidation IFRS 10 & IFRS 12 (CCT-PRJ-00315)
INFO 15:15:51,228 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option 278: TW IFRS 13 Fair Value Measurement
INFO 15:15:51,239 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option 281: TW IFRS7 Asset & Liabiliy ofsetting (CCT-PRJ-00319)
INFO 15:15:51,250 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option A-RISK Data Sourcing and Mgt Platform (IBS-PRJ-02978)
INFO 15:15:51,262 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Accounting Implementations_IBAS (GFI-PRJ-00306)
INFO 15:15:51,273 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Accounting Standards Adoption (IBS-PRJ-00390)
INFO 15:15:51,285 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option APAC WM (GFI-PRJ-00156)
INFO 15:15:51,298 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Application Capacity & Performance (IBS-PRJ-03383)
INFO 15:15:51,310 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Application Capacity (IBS-PRJ-02732)
INFO 15:15:51,321 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Atlas - TAS NA (IBS-PRJ-03931)
INFO 15:15:51,333 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Axiom Upgrade (EU & NA) (IBS-PRJ-03438)
INFO 15:15:51,344 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option B/S & RWA Management (IBS-PRJ-03400)
INFO 15:15:51,355 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option BAFTA (IBS-SOL-00801)
INFO 15:15:51,365 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Balance Sheet Netting (IBS-PRJ-03761)
INFO 15:15:51,377 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Basel II Finance (IBS-PRJ-01635)
INFO 15:15:51,389 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Basel III (CCT-PRJ-00275)
INFO 15:15:51,400 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option BI7 Tech Upgrade (IBS-PRJ-02731)
INFO 15:15:51,412 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Book Hierarchy (GFI-PRJ-00305)
INFO 15:15:51,423 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option BOXI-r3 Upgrade (GFI-PRJ-00164)
INFO 15:15:51,434 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Brazil Branch (IBS-PRJ-04964)
INFO 15:15:51,445 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option BSR - RMCR (GFI-PRJ-00158)
INFO 15:15:51,455 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option BUC IT RAD APPLICATIONS (IBS-SOL-00895)
INFO 15:15:51,467 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option BUC PB DATABASE (IBS-SOL-00814)
INFO 15:15:51,484 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option BUC PB DATABASE_ (GFI-PTR-00188)
INFO 15:15:51,495 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Calculation Engines - CTBM (IBS-PRJ-00873)
INFO 15:15:51,510 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Capacity Maintenance (IBS-PRJ-01648)
INFO 15:15:51,523 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Capital Optimization (IBS-PRJ-03454)
INFO 15:15:51,536 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CAS (Corporate Administration Services) (IBS-SOL-00815)
INFO 15:15:51,547 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CD: Data Quality & Remediation (IBS-PRJ-03098)
INFO 15:15:51,561 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Central VaR Reporting (RiskMAP) ZUR (IBS-PRJ-02679)
INFO 15:15:51,576 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option China Branch (IBS-PRJ-00552)
INFO 15:15:51,588 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option China Securities (IBS-PRJ-00554)
INFO 15:15:51,600 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CHINA SECURITIES_SO (IBS-SOL-00472)
INFO 15:15:51,612 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Close & Publication Project GCRS (GFI-PRJ-00298)
INFO 15:15:51,625 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Close & Publication Project GGL (GFI-PRJ-00297)
INFO 15:15:51,642 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CMIS (RTB / CTB-M / CTB - I) (IBS-PRJ-01693)
INFO 15:15:51,654 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CMIS - Maintenance (IBS-SOL-01393)
INFO 15:15:51,665 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CMIS - Management Reporting (IBS-PRJ-03738)
INFO 15:15:51,678 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CMIS -Level 1 Support (IBS-SOL-01339)
INFO 15:15:51,690 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CMIS -Level 2 Support (IBS-SOL-01340)
INFO 15:15:51,703 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CMIS REPORTING (IBS-SOL-00777)
INFO 15:15:51,719 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CONTRACT MANAGEMENT SYSTEM (CMS) (IBS-SOL-00802)
INFO 15:15:51,735 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option COSMOS (FX MM) (IBS-SOL-01425)
INFO 15:15:51,753 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option COSMOS (FX-MIS) (IBS-SOL-00816)
INFO 15:15:51,769 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option COSMOS (FXMM) (IBS-PRJ-03930)
INFO 15:15:51,784 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Cost Ledger Remediation (GFI-PRJ-00277)
INFO 15:15:51,796 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Credit Risk Level 2 Transactional (IBS-CMP-01154)
INFO 15:15:51,809 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Credit Risk PSC (IBS-CMP-01060)
INFO 15:15:51,821 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option CTB Maintenance (IBS-MIS-00161)
INFO 15:15:51,833 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Data Level 2 (IBS-CMP-00355)
INFO 15:15:51,844 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Data Management RTB Process (IBS-PRJ-03893)
INFO 15:15:51,857 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Data Metrics (IBS-PRJ-03898)
INFO 15:15:51,870 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Data Quality Enhancement (IBS-PRJ-01717)
INFO 15:15:51,883 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Database Management (IBS-PRJ-03380)
INFO 15:15:51,897 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Database Upgrades (IBS-PRJ-03386)
INFO 15:15:51,911 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option DQ Issue Management (IBS-PRJ-03482)
INFO 15:15:51,923 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option DSS Common Build (GFI-PTR-00214)
INFO 15:15:51,937 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option ECLAIMS (IBS-SOL-00817)
INFO 15:15:51,953 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option EF - MIS Maintenance (IBS-PRJ-01911)
INFO 15:15:51,966 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option EOL HW & OS Upgrades (GFI-PTR-00213)
INFO 15:15:51,980 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option EOL Software Upgrades (GFI-PTR-00215)
INFO 15:15:52,004 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option EOL Upgrades (GFI-PRJ-00167)
INFO 15:15:52,026 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Equities (GFI-PRJ-00157)
INFO 15:15:52,040 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Equities NRG (IBS-PRJ-02942)
INFO 15:15:52,055 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option EQUITY CONSOL (IBS-SOL-00809)
INFO 15:15:52,069 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option EQUITY CONSOL_ (GFI-PTR-00161)
INFO 15:15:52,084 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option ESS Common Build Implementation (IBS-PRJ-03387)
INFO 15:15:52,097 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option ETD Link (Brazil) (IBS-PRJ-04947)
INFO 15:15:52,113 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option EUA Remediation Program (GFI-PRJ-00242)
INFO 15:15:52,128 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Euro Agency Lending (CCT-PRJ-00326)
INFO 15:15:52,143 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Expense Management & Revenue Booking 5.0 (IBS-PRJ-03789)
INFO 15:15:52,157 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F-IT Reg App-Accounts Payable (IBS-SOL-00920)
INFO 15:15:52,179 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F-IT Reg App-Accounts Payable_ (GFI-PTR-00163)
INFO 15:15:52,197 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F-IT Reg App-Corporate Tax (IBS-SOL-00921)
INFO 15:15:52,219 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F-IT Reg App-Fin/Reg Reporting (IBS-SOL-00922)
INFO 15:15:52,236 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F-IT Reg App-Fin/Reg Reporting_ (GFI-PTR-00164)
INFO 15:15:52,252 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F2B Infra_Eq_Mandatory_GFIT (GFI-PRJ-00337)
INFO 15:15:52,267 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F2B Infra_Eq_ORI_GFIT (IBS-PRJ-03446)
INFO 15:15:52,282 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F2B Infra_EQ_Revenue_GFIT (GFI-PTR-00220)
INFO 15:15:52,298 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F2B Infra_FICC_Mandatory_GFIT (GFI-PRJ-00338)
INFO 15:15:52,318 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F2B Infra_FICC_ORI_GFIT (IBS-PRJ-03444)
INFO 15:15:52,336 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F2B Infra_FICC_Other_GFIT (GFI-PTR-00219)
INFO 15:15:52,352 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option F2B Infra_FICC_Revenue_GFIT (GFI-PTR-00218)
INFO 15:15:52,369 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Fair Value Hierarchy (IBS-PRJ-03391)
INFO 15:15:52,383 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FC Level 1 (IBS-CMP-00348)
INFO 15:15:52,398 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FCD GSD WEB (IBS-SOL-00918)
INFO 15:15:52,419 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FCD GSD WEB (KTLO) (GFI-PTR-00190)
INFO 15:15:52,440 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FDR - FICC / Equity Adoption / Mitigatin (IBS-PRJ-03448)
INFO 15:15:52,460 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FDW - FICC Attribute Onboarding (IBS-PRJ-03449)
INFO 15:15:52,479 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Fed Re-Write (GFI-PRJ-00169)
INFO 15:15:52,502 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FI Adoptions (IBS-PRJ-03152)
INFO 15:15:52,518 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Finance CTB Management (IBS-MIS-00150)
INFO 15:15:52,533 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Finance Data Sourcing - Equities (GFI-PRJ-00171)
INFO 15:15:52,550 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Finance Data Sourcing - FICC (GFI-PRJ-00172)
INFO 15:15:52,568 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Finance Data Sourcing - Reference (GFI-PRJ-00173)
INFO 15:15:52,585 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Finance Efficiencies for CTB-M (IBS-PRJ-03393)
INFO 15:15:52,599 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Finance IF Adoption (IBS-PRJ-03897)
INFO 15:15:52,617 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FIRARI (IBS-SOL-00810)
INFO 15:15:52,636 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FIRARI_ (GFI-PTR-00162)
INFO 15:15:52,656 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FIREHOUSE (IBS-SOL-00778)
INFO 15:15:52,676 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FIREHOUSE_ (GFI-PTR-00165)
INFO 15:15:52,690 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FTB Infra Equities (Finance) (IBS-PRJ-03446)
INFO 15:15:52,704 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FTB Infra Equities (IBS-PRJ-00392)
INFO 15:15:52,718 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FTB Infra Equities (Non-Finance) (IBS-PRJ-03447)
INFO 15:15:52,733 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FTB Infra FI (IBS-PRJ-00393)
INFO 15:15:52,749 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FTB Infra FICC (Finance) (IBS-PRJ-03444)
INFO 15:15:52,764 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FTB Infra FICC (Non-Finance) (IBS-PRJ-03445)
INFO 15:15:52,779 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FTB Infra MCC (IBS-PRJ-00394)
INFO 15:15:52,796 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Funding & Liquidity Management (IBS-PRJ-03401)
INFO 15:15:52,811 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option FX (GFI-PRJ-00160)
INFO 15:15:52,833 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GCRS Compliance (IBS-PRJ-03439)
INFO 15:15:52,854 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GCRS Ongoing Regulatory Changes_GRLS (GFI-PRJ-00283)
INFO 15:15:52,937 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GCRS Ongoing Regulatory Changes_IBAS (GFI-PRJ-00364)
INFO 15:15:52,952 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GCT Reporting & Optimisation (IBS-PRJ-03803)
INFO 15:15:52,967 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GETIT PORTAL (IBS-SOL-00804)
INFO 15:15:52,982 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GFI_Treasury_Funding_IBAS (GFI-PRJ-00086)
INFO 15:15:52,999 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GFI_Treasury_Remediation_IBAS (GFI-PRJ-00091)
INFO 15:15:53,018 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GFI_Treasury_Reporting_IBAS (GFI-PRJ-00092)
INFO 15:15:53,034 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL AUTOSYS (IBS-SOL-00762)
INFO 15:15:53,050 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL AUTOSYS_ (GFI-PTR-00182)
INFO 15:15:53,069 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL AXIOM (IBS-SOL-00765)
INFO 15:15:53,085 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL AXIOM_ (GFI-PTR-00175)
INFO 15:15:53,101 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL BO REPORTING (IBS-SOL-00763)
INFO 15:15:53,119 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL BO REPORTING_ (GFI-PTR-00166)
INFO 15:15:53,139 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL CAL (IBS-SOL-00764)
INFO 15:15:53,161 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL CAL_ (GFI-PTR-00170)
INFO 15:15:53,180 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL Delivery - I (IBS-PRJ-02456)
INFO 15:15:53,197 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL Delivery - M (IBS-PRJ-02457)
INFO 15:15:53,213 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL FBI (IBS-SOL-00916)
INFO 15:15:53,229 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL FBI_ (GFI-PTR-00181)
INFO 15:15:53,245 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL FDD (IBS-SOL-00766)
INFO 15:15:53,261 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL FDD_ (GFI-PTR-00172)
INFO 15:15:53,276 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL FDR (IBS-SOL-01413)
INFO 15:15:53,292 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL FDR_ (GFI-PTR-00183)
INFO 15:15:53,309 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL GGAT (IBS-SOL-00761)
INFO 15:15:53,327 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL GGAT_ (GFI-PTR-00174)
INFO 15:15:53,344 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL ICE (IBS-SOL-00767)
INFO 15:15:53,362 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL ICE_ (GFI-PTR-00184)
INFO 15:15:53,378 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL MERIDIAN (GFI-PTR-00168)
INFO 15:15:53,393 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL MERIDIAN (IBS-SOL-00768)
INFO 15:15:53,410 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL MERIDIAN_ (GFI-PTR-00168)
INFO 15:15:53,426 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL MOUSETRAP (IBS-SOL-00769)
INFO 15:15:53,443 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL MOUSETRAP_ (GFI-PTR-00185)
INFO 15:15:53,458 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL RAM (IBS-SOL-00770)
INFO 15:15:53,473 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL RAM_ (GFI-PTR-00186)
INFO 15:15:53,490 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL SAP BUSINESS WAREHOUSE (IBS-SOL-00771)
INFO 15:15:53,506 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL SAP BW + GGL R3 FIN (GFI-PTR-00127)
INFO 15:15:53,521 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL SAP R3 FINANCIALS (IBS-SOL-00772)
INFO 15:15:53,539 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL TAP (IBS-SOL-00917)
INFO 15:15:53,556 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL: IBID (IBS-SOL-00773)
INFO 15:15:53,574 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGL: IBID_ (GFI-PTR-00187)
INFO 15:15:53,590 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GGLTK J VENDOR (IBS-SOL-00919)
INFO 15:15:53,606 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Global Reg - Other (CCT-PRJ-00313)
INFO 15:15:53,622 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Global Valuations Issues Management (GFI-PRJ-00174)
INFO 15:15:53,639 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GMP - CTBM (IBS-PRJ-03707)
INFO 15:15:53,657 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GMP - Derivatives Monitoring (IBS-PRJ-03708)
INFO 15:15:53,673 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GRLS Lev 2 Finance Logistics (KTLO) (GFI-PTR-00157)
INFO 15:15:53,691 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GRLS Lev 2 NFL GCT (KTLO) (GFI-PTR-00160)
INFO 15:15:53,711 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GRLS Lev 2 NFL Logistics (KTLO) (GFI-PTR-00158)
INFO 15:15:53,728 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GRLS Lev 2 SAP R/3 & SAP BW (KTLO) (GFI-PTR-00159)
INFO 15:15:53,745 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Group Cost Transparency - Phase 1 (IBS-PRJ-01727)
INFO 15:15:53,762 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GROUP COST TRANSPARENCY CONTROL (IBS-SOL-00805)
INFO 15:15:53,780 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GSP - CTB-M (IBS-PRJ-03714)
INFO 15:15:53,799 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option GT Product Control (GFI-PRJ-00270)
INFO 15:15:53,819 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option HOLMES (IBS-SOL-00811)
INFO 15:15:53,845 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option HOLMES_ (GFI-PTR-00167)
INFO 15:15:53,864 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option HTA (IBS-SOL-00818)
INFO 15:15:53,886 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IB CONSOL (IBS-SOL-00780)
INFO 15:15:53,904 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IB CONSOL_ (GFI-PTR-00169)
INFO 15:15:53,922 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IB Reg Risk Remediation (GFI-PRJ-00275)
INFO 15:15:53,943 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IBAS Infra Remediation (GFI-PRJ-00289)
INFO 15:15:53,961 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IBAS Potential Risk and Efficiency Items (GFI-PRJ-00295)
INFO 15:15:53,980 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IBAS Risk Remediation (GFI-PRJ-00294)
INFO 15:15:53,998 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IBAS_Mgmt_Support (CtB) (GFI-PTR-00228)
INFO 15:15:54,019 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IBAS_Mgmt_Support (KTLO) (GFI-PTR-00212)
INFO 15:15:54,042 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IBMI_Reporting_IBAS (GFI-PRJ-00320)
INFO 15:15:54,060 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IBS_GCRS_Data_Sourcing (GFI-PRJ-00182)
INFO 15:15:54,082 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option iLog7 Upgrade (GFI-PRJ-00165)
INFO 15:15:54,101 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Independent Price Verification (IBS-PRJ-03450)
INFO 15:15:54,123 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option India Bank Branch (IBS-PRJ-02757)
INFO 15:15:54,142 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option India Core Banking Solution (IBS-PRJ-04937)
INFO 15:15:54,160 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Informatica Upgrade (GFI-PRJ-00166)
INFO 15:15:54,181 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Infrastructure Capacity (IBS-PRJ-02729)
INFO 15:15:54,202 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Int Fwk CF-CDL (IBS-CMP-00316)
INFO 15:15:54,222 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Int Fwk Core Framework Development (IBS-CMP-01187)
INFO 15:15:54,241 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Int Fwk Support (IBS-CMP-01189)
INFO 15:15:54,261 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Integrated Reporting (GFI-PRJ-00159)
INFO 15:15:54,282 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Integration Framework IB (IBS-SOL-00381)
INFO 15:15:54,303 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Integration FW Lingua Tools T1/010756 (IBS-PRJ-01938)
INFO 15:15:54,323 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IPV (Independent Price Verification) (GFI-PRJ-00273)
INFO 15:15:54,348 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IT FICC APAC - WM L-SSP (IBS-PRJ-03372)
INFO 15:15:54,378 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option IT Remediation (CCT-PRJ-00260)
INFO 15:15:54,410 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Korea Securities Re-engineering (IBS-PRJ-03441)
INFO 15:15:54,447 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option L&C Level 2 (IBS-CMP-00353)
INFO 15:15:54,469 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option L&F _Architecture_IBAS (GFI-PRJ-00313)
INFO 15:15:54,489 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option L&F Data_Sourcing and Reporting_IBAS (GFI-PRJ-00307)
INFO 15:15:54,511 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option L1 TAS (IBS-CMP-01262)
INFO 15:15:54,533 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option L1 Data (IBS-CMP-01264)
INFO 15:15:54,551 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option L1 FC (IBS-CMP-01263)
INFO 15:15:54,571 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option L1 FI Ops (IBS-CMP-01258)
INFO 15:15:54,595 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option L1 Margin Risk (IBS-CMP-01266)
INFO 15:15:54,615 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option L1 Recs (IBS-CMP-01267)
INFO 15:15:54,636 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Logistics - Prod Fixes & Level 3 Support (IBS-PRJ-01725)
INFO 15:15:54,656 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option LOGISTICS M.I.B (IBS-SOL-00820)
INFO 15:15:54,675 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Logistics Technical Upgrades (IBS-PRJ-01724)
INFO 15:15:54,698 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option London Axiom (IBS-PRJ-03442)
INFO 15:15:54,719 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Maint - Quant System (IBS-PRJ-03421)
INFO 15:15:54,740 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Management & Management Support (IBS-PRJ-01661)
INFO 15:15:54,765 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Management (IBS-PRJ-03389)
INFO 15:15:54,784 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Management Support (IBS-PRJ-03390)
INFO 15:15:54,803 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Market Risk Level 2 Transactional (IBS-CMP-01155)
INFO 15:15:54,825 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Market Risk PSC (IBS-CMP-01098)
INFO 15:15:54,844 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option MASTER DATA ADMINISTRATION SYSTEM (IBS-SOL-00800)
INFO 15:15:54,862 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Mercury_GFIT Buy Ins (GFI-PRJ-00324)
INFO 15:15:54,882 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Meridian (IBS-PRJ-01637)
INFO 15:15:54,901 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Metrics Capacity (IBS-PRJ-02730)
INFO 15:15:54,919 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option NFL Application Capacity & Performance (IBS-PRJ-03798)
INFO 15:15:54,937 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option NFL Database Upgrades (IBS-PRJ-03799)
INFO 15:15:54,957 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option NFL ESS Common Build & Implementation (IBS-PRJ-03800)
INFO 15:15:54,979 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option NFL Health Check Remediation (IBS-PRJ-03804)
INFO 15:15:54,998 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option NFL Logistics MIB (IBS-PRJ-03994)
INFO 15:15:55,017 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option NFL Software Upgrades (IBS-PRJ-03801)
INFO 15:15:55,039 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Notionals Project (GFI-PRJ-00248)
INFO 15:15:55,060 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option OCL_IBAS (GFI-PRJ-00316)
INFO 15:15:55,081 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option OCL_IBAS_Carry_Over (GFI-PRJ-00315)
INFO 15:15:55,101 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Offshoring (incl Logistics TOM) (IBS-PRJ-02174)
INFO 15:15:55,120 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option OLAP Reporting (GFI-PRJ-00162)
INFO 15:15:55,138 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Ongoing Regulatory and Group Tax Changes (IBS-PRJ-03440)
INFO 15:15:55,157 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Ongoing Regulatory Reporting Change (IBS-PRJ-02176)
INFO 15:15:55,177 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Operational Risk Suite (IBS-SOL-00774)
INFO 15:15:55,198 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Ops&Ctrl - Apps Testing &Rem (IBS-PRJ-03768)
INFO 15:15:55,216 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option OPTIMA (IBS-SOL-00821)
INFO 15:15:55,237 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Oracle 11G Upgrades (GFI-PRJ-00163)
INFO 15:15:55,261 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option ORI Release 19 (IBS-PRJ-03802)
INFO 15:15:55,282 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Overhead
INFO 15:15:55,303 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option P&L Attribution (GFI-PRJ-00271)
INFO 15:15:55,326 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option P&L Explain (IBS-PRJ-03451)
INFO 15:15:55,349 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Pactual Day 2 (IBS-PRJ-03827)
INFO 15:15:55,377 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Pactual Day 2 (incl OTC integration) (IBS-PRJ-00506)
INFO 15:15:55,398 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Personal Compliance - CTBM (IBS-PRJ-03716)
INFO 15:15:55,428 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option PIP - Continuous Integration (GFI-PTR-00230)
INFO 15:15:55,449 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option PRICE VARIANCE (IBS-SOL-00824)
INFO 15:15:55,469 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Price Variance (KTLO) (GFI-PTR-00191)
INFO 15:15:55,491 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RAD - R (IBS-SOL-00895)
INFO 15:15:55,512 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RAD - R_ (GFI-PTR-00171)
INFO 15:15:55,533 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RAD I (IBS-PRJ-02182)
INFO 15:15:55,554 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RAD M (IBS-PRJ-02179)
INFO 15:15:55,574 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RAD Remediation (IBS-PRJ-03453)
INFO 15:15:55,598 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RAD_ORI_GFIT (GFI-PRJ-00339)
INFO 15:15:55,621 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RAD_Revenue_GFIT (GFI-PRJ-00340)
INFO 15:15:55,642 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RADAR (IBS-SOL-00155)
INFO 15:15:55,661 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Ranger FE Migration (IBS-PRJ-03443)
INFO 15:15:55,683 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RANGER P AND L (IBS-SOL-00812)
INFO 15:15:55,705 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RANGER P AND L_ (GFI-PTR-00173)
INFO 15:15:55,725 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Rapid Application Development (IBS-PRJ-03452)
INFO 15:15:55,744 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RBP&L (GFI-PRJ-00272)
INFO 15:15:55,765 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Real Estate Managment / KTLO (GFI-PTR-00007)
INFO 15:15:55,786 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Reg Essential Maintenance (IBS-PRJ-03480)
INFO 15:15:55,806 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Reg Req Change (IBS-PRJ-03440)
INFO 15:15:55,827 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option RFA / FX Reval (IBS-PRJ-03392)
INFO 15:15:55,849 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Risk Cash Systems (Capacity) (IBS-PRJ-03306)
INFO 15:15:55,869 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Risk IT Integration Framework Adoption (IBS-PRJ-00535)
INFO 15:15:55,892 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Russia Re-Engineering (IBS-PRJ-03760)
INFO 15:15:55,912 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Russia/Cyprus SUN GL replacement (GGL) (GFI-PRJ-00168)
INFO 15:15:55,932 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Russia/Cyprus SUN GL Replacement (IB) (IBS-PRJ-05417)
INFO 15:15:55,951 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option SAP GCT (IBS-SOL-00807)
INFO 15:15:55,975 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option SAP GCT / KTLO (GFI-PTR-00041)
INFO 15:15:55,995 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Server Management (IBS-PRJ-03381)
INFO 15:15:56,016 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option SINGLE COST TOOL (IBS-SOL-00826)
INFO 15:15:56,038 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option SINGLE COST TOOL_ (GFI-PTR-00176)
INFO 15:15:56,056 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option SOCRATES (IBS-SOL-00813)
INFO 15:15:56,079 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Socrates Migration (GFI-PRJ-00161)
INFO 15:15:56,102 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Socrates Tech Upgrade (IBS-PRJ-02181)
INFO 15:15:56,125 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option SOCRATES_ (GFI-PTR-00177)
INFO 15:15:56,145 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Software Upgrades (IBS-PRJ-03388)
INFO 15:15:56,171 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Storage Infra (IBS-CMP-01016)
INFO 15:15:56,195 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Storage Management (IBS-PRJ-03382)
INFO 15:15:56,221 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Strategic Common Data Sourcing (GFI-PRJ-00299)
INFO 15:15:56,242 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Strategic Data Initiatives (IBS-PRJ-03483)
INFO 15:15:56,261 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option TAP (Treasury Analysis Project) (IBS-PRJ-00724)
INFO 15:15:56,284 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option TAX OPERATIONS (IBS-SOL-00829)
INFO 15:15:56,306 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option TAX OPERATIONS_ (GFI-PTR-00178)
INFO 15:15:56,325 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option TIME ENTRY SYSTEM (IBS-SOL-00808)
INFO 15:15:56,349 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Top Issue Resolution & Metrics (GFI-PRJ-00247)
INFO 15:15:56,377 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option TRACS (IBS-SOL-01452)
INFO 15:15:56,409 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option TRACS_ (GFI-PTR-00179)
INFO 15:15:56,434 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Training - CTBM (IBS-PRJ-03721)
INFO 15:15:56,456 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Treasury Reg Risk Remediation (GFI-PRJ-00276)
INFO 15:15:56,475 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option UBS Securities (US Broker/Dealer) (GFI-PRJ-00170)
INFO 15:15:56,496 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option VISUAL JG (VJG) (IBS-SOL-00827)
INFO 15:15:56,517 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option WORKPACKAGE APPROVAL SYSTEM (WPAS) (IBS-SOL-00828)
INFO 15:15:56,552 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option Year End Carryforward (IBS-CMP-01291)
INFO 15:15:56,575 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option ZCAL (IBS-SOL-00775)
INFO 15:15:56,597 [Custom Field Cost Object] [Scheme [IMOT]] [Config Default Configuration for Cost Object] Creating option ZCAL_ (GFI-PTR-00180)
INFO 15:15:56,651 [Custom Field Cost Object] [Scheme [IMOT]] Creating association for issue type null to FieldConfig Default Configuration for Cost Object
INFO 15:15:56,841 [Custom Field Iteration Priority] Creating configuration scheme [IMOT]
INFO 15:15:56,912 [Custom Field Iteration Priority] [Scheme [IMOT]] Creating configuration Default Configuration for Iteration Priority
INFO 15:15:56,957 [Custom Field Iteration Priority] [Scheme [IMOT]] [Config Default Configuration for Iteration Priority] Creating option Must Have
INFO 15:15:56,974 [Custom Field Iteration Priority] [Scheme [IMOT]] [Config Default Configuration for Iteration Priority] Creating option Should Have
INFO 15:15:57,000 [Custom Field Iteration Priority] [Scheme [IMOT]] [Config Default Configuration for Iteration Priority] Creating option Could Have
INFO 15:15:57,010 [Custom Field Iteration Priority] [Scheme [IMOT]] [Config Default Configuration for Iteration Priority] Creating option Won't Have
INFO 15:15:57,070 [Custom Field Iteration Priority] [Scheme [IMOT]] Creating association for issue type null to FieldConfig Default Configuration for Iteration Priority
INFO 15:15:57,319 [Custom Field Risk Impact] Creating configuration scheme [IMOT]
INFO 15:15:57,390 [Custom Field Risk Impact] [Scheme [IMOT]] Creating configuration Default Configuration for Risk Impact
INFO 15:15:57,438 [Custom Field Risk Impact] [Scheme [IMOT]] [Config Default Configuration for Risk Impact] Creating option 0
INFO 15:15:57,450 [Custom Field Risk Impact] [Scheme [IMOT]] [Config Default Configuration for Risk Impact] Creating option 1
INFO 15:15:57,482 [Custom Field Risk Impact] [Scheme [IMOT]] [Config Default Configuration for Risk Impact] Creating option 2
INFO 15:15:57,494 [Custom Field Risk Impact] [Scheme [IMOT]] [Config Default Configuration for Risk Impact] Creating option 3
INFO 15:15:57,520 [Custom Field Risk Impact] [Scheme [IMOT]] [Config Default Configuration for Risk Impact] Creating option 4
INFO 15:15:57,541 [Custom Field Risk Impact] [Scheme [IMOT]] [Config Default Configuration for Risk Impact] Creating option 5
INFO 15:15:57,550 [Custom Field Risk Impact] [Scheme [IMOT]] [Config Default Configuration for Risk Impact] Modifying default value to: 0
INFO 15:15:57,610 [Custom Field Risk Impact] [Scheme [IMOT]] Creating association for issue type Risk to FieldConfig Default Configuration for Risk Impact
INFO 15:15:57,772 [Custom Field Risk Probability] Creating configuration scheme [IMOT]
INFO 15:15:57,846 [Custom Field Risk Probability] [Scheme [IMOT]] Creating configuration Default Configuration for Risk Probability
INFO 15:15:57,892 [Custom Field Risk Probability] [Scheme [IMOT]] [Config Default Configuration for Risk Probability] Creating option 0
INFO 15:15:57,904 [Custom Field Risk Probability] [Scheme [IMOT]] [Config Default Configuration for Risk Probability] Creating option 1
INFO 15:15:57,915 [Custom Field Risk Probability] [Scheme [IMOT]] [Config Default Configuration for Risk Probability] Creating option 2
INFO 15:15:57,925 [Custom Field Risk Probability] [Scheme [IMOT]] [Config Default Configuration for Risk Probability] Creating option 3
INFO 15:15:57,937 [Custom Field Risk Probability] [Scheme [IMOT]] [Config Default Configuration for Risk Probability] Creating option 4
INFO 15:15:57,951 [Custom Field Risk Probability] [Scheme [IMOT]] [Config Default Configuration for Risk Probability] Creating option 5
INFO 15:15:57,962 [Custom Field Risk Probability] [Scheme [IMOT]] [Config Default Configuration for Risk Probability] Modifying default value to: 0
INFO 15:15:58,016 [Custom Field Risk Probability] [Scheme [IMOT]] Creating association for issue type Risk to FieldConfig Default Configuration for Risk Probability
INFO 15:15:58,200 [Custom Field PPM] Creating configuration scheme [IMOT]
INFO 15:15:58,266 [Custom Field PPM] [Scheme [IMOT]] Creating configuration Default Configuration for ITG
INFO 15:15:58,355 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Task to FieldConfig Default Configuration for ITG
INFO 15:15:58,522 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Issue to FieldConfig Default Configuration for ITG
INFO 15:15:58,673 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Documentation to FieldConfig Default Configuration for ITG
INFO 15:15:58,778 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Risk to FieldConfig Default Configuration for ITG
INFO 15:15:58,888 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type New Feature to FieldConfig Default Configuration for ITG
INFO 15:15:59,018 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Functional Feature to FieldConfig Default Configuration for ITG
INFO 15:15:59,134 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Requirement to FieldConfig Default Configuration for ITG
INFO 15:15:59,264 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Improvement to FieldConfig Default Configuration for ITG
INFO 15:15:59,394 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Debt to FieldConfig Default Configuration for ITG
INFO 15:15:59,535 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Development to FieldConfig Default Configuration for ITG
INFO 15:15:59,768 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Infrastructure to FieldConfig Default Configuration for ITG
INFO 15:15:59,905 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Investigation to FieldConfig Default Configuration for ITG
INFO 15:16:00,066 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Technical Feature to FieldConfig Default Configuration for ITG
INFO 15:16:00,462 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Defect to FieldConfig Default Configuration for ITG
INFO 15:16:00,618 [Custom Field PPM] [Scheme [IMOT]] Creating association for issue type Testing to FieldConfig Default Configuration for ITG
INFO 15:16:00,790 [Custom Field Quality Center Ticket] Creating configuration scheme [IMOT]
INFO 15:16:00,868 [Custom Field Quality Center Ticket] [Scheme [IMOT]] Creating configuration Default Configuration for QC Ticket
INFO 15:16:00,972 [Custom Field Quality Center Ticket] [Scheme [IMOT]] Creating association for issue type Issue to FieldConfig Default Configuration for QC Ticket
INFO 15:16:01,133 [Custom Field Quality Center Ticket] [Scheme [IMOT]] Creating association for issue type Defect to FieldConfig Default Configuration for QC Ticket
INFO 15:16:01,572 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Cost Object] Modifying position to: 18
INFO 15:16:01,584 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multigrouppicker:Resource] Modifying position to: 19
INFO 15:16:01,605 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multiselect:Category] Modifying position to: 20
INFO 15:16:01,624 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV/Reserve] Modifying position to: 22
INFO 15:16:01,667 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Priority Comment] Modifying position to: 23
INFO 15:16:01,708 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Next Action Comment] Modifying position to: 24
INFO 15:16:01,775 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Stakeholder] Modifying position to: 25
INFO 15:16:01,813 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Name] Modifying position to: 26
INFO 15:16:01,848 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:RTB Manager Approval] Modifying position to: 27
INFO 15:16:01,882 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Release Item Status] Modifying position to: 28
INFO 15:16:01,912 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Priority] Modifying position to: 29
INFO 15:16:01,943 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textarea:User Test Cases] Modifying position to: 30
INFO 15:16:01,973 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multiselect:STIR Reports] Modifying position to: 31
INFO 15:16:02,017 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV Issue Type] Modifying position to: 32
INFO 15:16:02,041 [Screen FIT Create Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Reviewer] Modifying position to: 33
INFO 15:16:02,061 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Cost Object] Modifying position to: 15
INFO 15:16:02,069 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV/Reserve] Modifying position to: 16
INFO 15:16:02,085 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Priority Comment] Modifying position to: 17
INFO 15:16:02,103 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Next Action Comment] Modifying position to: 18
INFO 15:16:02,125 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Stakeholder] Modifying position to: 19
INFO 15:16:02,143 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Name] Modifying position to: 20
INFO 15:16:02,161 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:RTB Manager Approval] Modifying position to: 21
INFO 15:16:02,180 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Release Item Status] Modifying position to: 22
INFO 15:16:02,198 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textarea:User Test Cases] Modifying position to: 23
INFO 15:16:02,213 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multiselect:STIR Reports] Modifying position to: 24
INFO 15:16:02,232 [Screen FIT Default Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Reviewer] Modifying position to: 25
INFO 15:16:02,252 [Screen FIT Default Screen] [Tab Field Tab] [Field labels] Modifying position to: 26
INFO 15:16:02,269 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Cost Object] Modifying position to: 14
INFO 15:16:02,282 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textarea:Benefit Description] Modifying position to: 15
INFO 15:16:02,303 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:float:Benefit Estimate (hrs)] Modifying position to: 16
INFO 15:16:02,320 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Customer] Modifying position to: 17
INFO 15:16:02,336 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multigrouppicker:Resource] Modifying position to: 18
INFO 15:16:02,356 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multiselect:Category] Modifying position to: 19
INFO 15:16:02,376 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV/Reserve] Modifying position to: 21
INFO 15:16:02,411 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Priority Comment] Modifying position to: 22
INFO 15:16:02,435 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Next Action Comment] Modifying position to: 23
INFO 15:16:02,464 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Stakeholder] Modifying position to: 24
INFO 15:16:02,514 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Name] Modifying position to: 25
INFO 15:16:02,548 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:RTB Manager Approval] Modifying position to: 26
INFO 15:16:02,580 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Release Item Status] Modifying position to: 27
INFO 15:16:02,607 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textarea:User Test Cases] Modifying position to: 28
INFO 15:16:02,634 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multiselect:STIR Reports] Modifying position to: 29
INFO 15:16:02,660 [Screen FIT Edit Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Reviewer] Modifying position to: 30
INFO 15:16:02,680 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Quality Center Ticket] Modifying position to: 14
INFO 15:16:02,689 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV/Reserve] Modifying position to: 15
INFO 15:16:02,706 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Priority Comment] Modifying position to: 16
INFO 15:16:02,722 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Next Action Comment] Modifying position to: 17
INFO 15:16:02,739 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Stakeholder] Modifying position to: 18
INFO 15:16:02,754 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Name] Modifying position to: 19
INFO 15:16:02,769 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:RTB Manager Approval] Modifying position to: 20
INFO 15:16:02,783 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Release Item Status] Modifying position to: 21
INFO 15:16:02,798 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textarea:User Test Cases] Modifying position to: 22
INFO 15:16:02,813 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multiselect:STIR Reports] Modifying position to: 23
INFO 15:16:02,829 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV Issue Type] Modifying position to: 24
INFO 15:16:02,842 [Screen FIT Old Create Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Reviewer] Modifying position to: 25
INFO 15:16:02,855 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Quality Center Ticket] Modifying position to: 13
INFO 15:16:02,864 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV/Reserve] Modifying position to: 14
INFO 15:16:02,887 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Priority Comment] Modifying position to: 15
INFO 15:16:02,904 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Next Action Comment] Modifying position to: 16
INFO 15:16:02,923 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Stakeholder] Modifying position to: 17
INFO 15:16:02,957 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Name] Modifying position to: 18
INFO 15:16:02,973 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:RTB Manager Approval] Modifying position to: 19
INFO 15:16:02,990 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Release Item Status] Modifying position to: 20
INFO 15:16:03,006 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textarea:User Test Cases] Modifying position to: 21
INFO 15:16:03,024 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multiselect:STIR Reports] Modifying position to: 22
INFO 15:16:03,042 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV Issue Type] Modifying position to: 23
INFO 15:16:03,059 [Screen FIT Old Edit Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Reviewer] Modifying position to: 24
INFO 15:16:03,072 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV/Reserve] Modifying position to: 14
INFO 15:16:03,081 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Priority Comment] Modifying position to: 15
INFO 15:16:03,098 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Next Action Comment] Modifying position to: 16
INFO 15:16:03,114 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Stakeholder] Modifying position to: 17
INFO 15:16:03,134 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Name] Modifying position to: 18
INFO 15:16:03,151 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:RTB Manager Approval] Modifying position to: 19
INFO 15:16:03,167 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Release Item Status] Modifying position to: 20
INFO 15:16:03,185 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textarea:User Test Cases] Modifying position to: 21
INFO 15:16:03,201 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multiselect:STIR Reports] Modifying position to: 22
INFO 15:16:03,217 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV Issue Type] Modifying position to: 23
INFO 15:16:03,234 [Screen FIT Old View Defect Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Reviewer] Modifying position to: 24
INFO 15:16:03,254 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV/Reserve] Modifying position to: 19
INFO 15:16:03,263 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Priority Comment] Modifying position to: 20
INFO 15:16:03,279 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Next Action Comment] Modifying position to: 21
INFO 15:16:03,295 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Stakeholder] Modifying position to: 22
INFO 15:16:03,314 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textfield:Name] Modifying position to: 23
INFO 15:16:03,333 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:RTB Manager Approval] Modifying position to: 24
INFO 15:16:03,350 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:Release Item Status] Modifying position to: 25
INFO 15:16:03,373 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:textarea:User Test Cases] Modifying position to: 26
INFO 15:16:03,396 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:multiselect:STIR Reports] Modifying position to: 27
INFO 15:16:03,443 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:select:IPV Issue Type] Modifying position to: 28
INFO 15:16:03,459 [Screen FIT View Issue Screen] [Tab Field Tab] [Field com.atlassian.jira.plugin.system.customfieldtypes:userpicker:Reviewer] Modifying position to: 29
INFO 15:16:04,514 Creating workflow scheme IMO Workflow Scheme
INFO 15:16:04,537 [Workflow Scheme IMO Workflow Scheme] Associating issue type null with workflow FIT classic workflow
INFO 15:16:12,255 [Project IMOT] Deleting members for project role Project Management
INFO 15:16:12,272 [Project IMOT] [Actual members for project role Administrators] Setting member users to: [reineckj, sharmain, mansells, austintr, edwardal, khanj, eldadayo, galest, westro, okellyma]
INFO 15:16:12,293 [Project IMOT] [Actual members for project role Developers] Setting member users to: [reineckj, sharmain, mansells, austintr, edwardal, khanj, eldadayo, galest, westro, okellyma]
INFO 15:16:12,304 [Project IMOT] [Actual members for project role Developers] Setting member groups to: []
INFO 15:16:12,309 [Project IMOT] [Actual members for project role Managers] Setting member users to: [reineckj, mansells, austintr, edwardal, eldadayo, galest, westro, okellyma]
INFO 15:16:12,320 [Project IMOT] [Actual members for project role Users] Setting member users to: [reineckj, mansells, austintr, edwardal, eldadayo, galest, westro, okellyma]
WARN 15:16:12,330 Skipping versions...
WARN 15:16:12,330 Skipping components...
WARN 15:16:12,881 Trying to rollback changes in database...
WARN 15:16:56,019 Rollback finished
java.lang.IllegalStateException: Too many PermissionScheme schemes found for Project VGSORI
at com.atlassian.jira.scheme.AbstractSchemeManager.getSchemeIdFor(AbstractSchemeManager.java:275)
at com.atlassian.jira.permission.DefaultPermissionSchemeManager.getSchemeIdFor(DefaultPermissionSchemeManager.java:628)
at com.atlassian.jira.permission.DefaultPermissionSchemeManager.hasSchemePermission(DefaultPermissionSchemeManager.java:584)
at com.atlassian.jira.security.DefaultPermissionManager.doProjectPermissionCheck(DefaultPermissionManager.java:354)
at com.atlassian.jira.security.DefaultPermissionManager.hasPermission(DefaultPermissionManager.java:208)
at com.atlassian.jira.security.WorkflowBasedPermissionManager.hasPermission(WorkflowBasedPermissionManager.java:130)
at com.atlassian.jira.security.DefaultPermissionManager$4.apply(DefaultPermissionManager.java:524)
at com.atlassian.jira.security.DefaultPermissionManager$4.apply(DefaultPermissionManager.java:520)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:649)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:143)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:138)
at com.google.common.collect.Lists.newArrayList(Lists.java:138)
at com.google.common.collect.Lists.newArrayList(Lists.java:119)
at com.atlassian.jira.security.DefaultPermissionManager.getProjectObjectsWithPermission(DefaultPermissionManager.java:519)
at com.atlassian.jira.security.DefaultPermissionManager.getProjectObjects(DefaultPermissionManager.java:444)
at com.atlassian.jira.security.ThreadLocalCachingPermissionManager.getProjectObjects(ThreadLocalCachingPermissionManager.java:43)
at com.atlassian.jira.security.DefaultPermissionManager.getProjects(DefaultPermissionManager.java:439)
at sun.reflect.GeneratedMethodAccessor454.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.atlassian.util.profiling.object.ObjectProfiler.profiledInvoke(ObjectProfiler.java:83)
at com.atlassian.jira.config.component.SwitchingInvocationHandler.invoke(SwitchingInvocationHandler.java:28)
at com.sun.proxy.$Proxy14.getProjects(Unknown Source)
at com.atlassian.jira.issue.search.parameters.lucene.DefaultPermissionQueryFactory.getQuery(DefaultPermissionQueryFactory.java:65)
at com.atlassian.jira.issue.search.parameters.lucene.PermissionsFilterGeneratorImpl.getQuery(PermissionsFilterGeneratorImpl.java:40)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.getPermissionsFilter(LuceneSearchProvider.java:543)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.getHitCount(LuceneSearchProvider.java:251)
at com.atlassian.jira.issue.search.providers.LuceneSearchProvider.searchCount(LuceneSearchProvider.java:123)
at com.atlassian.jira.bc.issue.search.DefaultSearchService.searchCount(DefaultSearchService.java:123)
at com.awnaba.projectconfigurator.jiraobjectfacades.IssueTypeToolsImpl.numberOfIssuesWithType(IssueTypeToolsImpl.java:81)
at com.awnaba.projectconfigurator.jiraobjectfacades.IssueTypeSchemeToolsImpl.checkIssueTypesInUse(IssueTypeSchemeToolsImpl.java:127)
at com.awnaba.projectconfigurator.jiraobjectfacades.IssueTypeSchemeToolsImpl.checkIssueTypesInUse(IssueTypeSchemeToolsImpl.java:104)
at com.awnaba.projectconfigurator.loaders.handlers.JiraProjectHandler$7.propertySetLogMessage(JiraProjectHandler.java:290)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler$2.logMessageContent(AbstractIntegratedHandler.java:263)
at com.awnaba.projectconfigurator.loaders.core.AbstractLogger.log(AbstractLogger.java:23)
at com.awnaba.projectconfigurator.loaders.core.AbstractSmartPropertySetter.smartSet(AbstractSmartPropertySetter.java:13)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler.processOnepropertyHelper(AbstractIntegratedHandler.java:279)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler.processPropertyActionList(AbstractIntegratedHandler.java:240)
at com.awnaba.projectconfigurator.loaders.core.AbstractIntegratedHandler.handleSubordinatesAndProperties(AbstractIntegratedHandler.java:212)
at com.awnaba.projectconfigurator.loaders.handlers.JiraProjectHandler.finishHandling(JiraProjectHandler.java:575)
at com.awnaba.projectconfigurator.loaders.handlers.ProjectConfigLoader.loadOperations(ProjectConfigLoader.java:145)
at com.awnaba.projectconfigurator.loaders.handlers.ProjectConfigLoader.doLoad(ProjectConfigLoader.java:78)
at com.awnaba.projectconfigurator.ProjectConfigUploadPageAction.doLoad(ProjectConfigUploadPageAction.java:360)
at com.awnaba.projectconfigurator.ProjectConfigUploadPageAction.doExecute(ProjectConfigUploadPageAction.java:313)
at webwork.action.ActionSupport.execute(ActionSupport.java:165)
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:88)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:225)
at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:154)
at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87)
at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70)
at com.atlassian.jira.onboarding.postsetup.ui.PostSetupAnnouncementsFilter.doFilter(PostSetupAnnouncementsFilter.java:61)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:40)
at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:59)
at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36)
at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92)
at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56)
at com.intenso.jira.contentinjection.filter.ContentInjectionFilter.doFilter(ContentInjectionFilter.java:71)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:107)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:91)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:181)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:85)
at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
at com.atlassian.jira.web.filters.pagebuilder.PageBuilderFilter.doFilter(PageBuilderFilter.java:90)
at com.atlassian.jira.web.filters.CommittedResponseHtmlErrorRecoveryFilter.doFilter(CommittedResponseHtmlErrorRecoveryFilter.java:63)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:239)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:172)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:79)
at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:40)
at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:79)
at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41)
at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:61)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:115)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:92)
at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:56)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:610)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Roy Chapman
I have found the problem.  A previous project (VGSORI as in the error) must have imported incorrectly.  This was effectively an empty project.  I have now deleted this project and these configs come in OK.  Investigating the possible issue with the VGSORI project
José Marañón [Awnaba Software S.L.]
September 4, 2015
Glad you had already fixed it!
When the plugin is about to assign an issue type scheme to a project, it runs a query to verify if the new scheme is compatible with the issue types existing in the project. In this case, as a preparation to running that query, JIRA has checked permissions and the check has crashed when it found that project VGSORI had more than one permission scheme. As you can see, project VGSORI had nothing to do with the import.
Just to throw a bit more light on what has happened...
Prashant Mali
February 3, 2019
I also want the root cause for the same.
Prashant
