Need a script in a post function that depending on a custom field value changes the Issue Type.
Pete Bladon August 21, 2017
We require a scriptrunner script that allows us to change the issue type in a post function called TRIAGE, based on the contents of a cascade select custom field that will have two linked values, such as Application -> Desktop Support, that will then change the Issue type to Desktop Support.
The initial state for the Issue Type would be TRIAGE, there will be around 20 different issue types based on the contents of the custom field.
Anyone have any examples on how to change the Issue Type? I have been looking and havent found anything directly scripting this type of change.
Joshua Yamdogo @ Adaptavist
August 21, 2017
This script should work.
def cascadingSelect = customFieldManager.getCustomFieldObjectByName("CascadingSelect")
def cascadingOptions = issue.getCustomFieldValue(cascadingSelect) as Map
def cascadingValues = [cascadingOptions.get(null) as String, cascadingOptions.get("1") as String]
if (cascadingValues == ['Application', 'Desktop Support']) {
issue.setIssueTypeId("10101") // issue type id here
else if (cascadingValues == ['Application', 'Desktop Support']) {
// and so on
else {
// and so on
You'll just have to add more else if blocks. You'll also need to have the correct issueTypeId to use (https://confluence.atlassian.com/display/JIRA050/Finding+the+Id+for+Issue+Types)
