No re-index in bulk operation when copy issue function of JIRA Utilities is set in workflow
hirok March 14, 2013
I have a workflow transition which contains copy issue function in JIRA Utilities. The transition changes issue status.
The copy function is working fine and I don't see any problem when I execute the transition one by one.
However, I execute the transition from bulk operation, it looks all the issue are NOT re-indexed.
Because I see all the status are not changed on the issue navigator view after the bulk operation. However I open and see the status was changed in each issue.
Performing re-Indexing from administrator menu solves this issue, but it takes huge amount of time!
If you have any solution, please let me know.
hiro
Theinvisibleman
March 14, 2013
Hi Hiro,
I think that for this issue, it would be better if you raise an issue in the add-on's issue tracker, which you can find here or contact the vendor of the plugin here.
Joe
hirok March 17, 2013
Hi Joe,
Thanks for your advice.
I requested the vendor to investigate this issue and I got a ticket.
I'll let you know when I get any update.
hiro
