×I am using Power BI desktop and used the template content pack to retrieve data from JIRA, i could able to get all the records with data of original jira field but the custom field data is null for all the custom field.
Can somebody let me know where is the issue. I have used the adavanced editor to modiy the query ?
#"Expanded Column1" = Table.ExpandRecordColumn(Source, "Column1", {"expand", "id", "self", "key", "fields"}, {"expand", "id", "self", "key", "fields"}),
#"Expanded fields" = Table.ExpandRecordColumn(#"Expanded Column1", "fields", {"issuetype", "timespent", "project", "fixVersions", "customfield_10110", "customfield_10111", "aggregatetimespent", "resolution", "customfield_10112", "customfield_10113", "customfield_10114", "customfield_10104", "customfield_10105", "customfield_10106", "customfield_10107", "customfield_10108", "customfield_10109", "resolutiondate", "workratio", "lastViewed", "watches", "created", "priority", "customfield_10100", "customfield_10101", "customfield_10102", "customfield_10103", "labels", "timeestimate", "aggregatetimeoriginalestimate", "versions", "issuelinks", "assignee", "updated", "status", "components", "timeoriginalestimate", "description", "customfield_10006", "customfield_10009", "aggregatetimeestimate", "summary", "creator", "subtasks", "reporter", "customfield_10000", "aggregateprogress", "customfield_10001", "customfield_10004", "customfield_10115", "customfield_10116", "customfield_10117", "environment", "customfield_10118", "customfield_10119", "duedate", "progress", "votes", "parent", "customfield_10005", "customfield_10007", "customfield_10008", "customfield_10002", "customfield_10003", "customfield_13734", "customfield_13733"}, {"issuetype", "timespent", "project", "fixVersions", "customfield_10110", "customfield_10111", "aggregatetimespent", "resolution", "customfield_10112", "customfield_10113", "customfield_10114", "customfield_10104", "customfield_10105", "customfield_10106", "customfield_10107", "customfield_10108", "customfield_10109", "resolutiondate", "workratio", "lastViewed", "watches", "created", "priority", "customfield_10100", "customfield_10101", "customfield_10102", "customfield_10103", "labels", "timeestimate", "aggregatetimeoriginalestimate", "versions", "issuelinks", "assignee", "updated", "status", "components", "timeoriginalestimate", "description", "customfield_10006", "customfield_10009", "aggregatetimeestimate", "summary", "creator", "subtasks", "reporter", "customfield_10000", "aggregateprogress", "customfield_10001", "customfield_10004", "customfield_10115", "customfield_10116", "customfield_10117", "environment", "customfield_10118", "customfield_10119", "duedate", "progress", "votes", "parent", "customfield_10005", "customfield_10007", "customfield_10008", "customfield_10002", "customfield_10003", "customfield_13734", "customfield_13733"}),
