×Super - now it works
Thanks a lot
Kind regards
Claus Nielsen
Nykredit Realkredit
we have released new version 0.1.0
https://marketplace.atlassian.com/plugins/com.codedoers.jira.repeating-issues/versions.
Could you check what is the result after updating Repeating Issues?
regards,
CodeDoers Team
Hi CodeDoers,
How can I solve this ? Do you need logfiles ?
Kind regards
Claus Nielsen
Nykredit Realkredit
Hi CodeDoers,
I have rebuilded the index, and the problem is still the same.
Kind regards
Claus Nielsen
Hello Claus,
Did you made any changes in your Jira instance that can result in the search index becoming out-of-sync with JIRA's configuration?. If yes, then you need to rebuild JIRA's search index.
Please re-index your JIRA instance and try again to set repeating for issue.
Best regards,
CodeDoers Team
