I followed instructions on https://scriptrunner.adaptavist.com/latest/jira/testing.html on how to run unit tests from IDE, but I can't successfully authenticate.
Log header: Authorization: Basic YWRtaW46YWRtaW4= (I guess this is admin/admin)
I am getting 403 Authentication denied, because I don't have (admin/admin) user.
How can I change credentials for running unit tests from IDE?
OK, managed to do it with extending
class JiraScriptRunnerTestRunner extends ScriptRunnerTestRunner
and overriding
@Override
void run(RunNotifier notifier)
Anyway it would be nice if scriptrunner would allow us to specify username and password as a '-D' System property, same like with baseurl
def baseUrl = System.getProperty("baseurl", "http://localhost:8080/jira")
Are you able to share how you modified `run` in your override? I tried copying and pasting the decompiled class's method so I could replace the "admin/admin" string, but I couldn't get it to compile.
