SIL Power Scripts - create screen schemes
Chris Dunne {Raledo}
Is it possible to use SIL to create screen schemes and issue type screen schemes. I see it is possible to create screens using admCreateScreen and add fields using admAddFieldToScreen, but I don't see a way to create the schemes.
Chris
Jonathan Muse {Appfire}
January 10, 2018
@Chris Dunne {Raledo}, I could get this added as a feature request if you would like. Could you let me know how you intended on using this?
Evgeniy Russkikh
hello!
I'm surprised that SIL can't create any schemes. I think it will be very useful to have routines to create all schemes (issue type scheme, workflow and workflow schemes, screen schemes, issue type screen schemes etc.)
April 24, 2018
@Evgeniy Russkikh new routines are usually created based on a request and up to this point, no one has expressed much interest in this functionality. However, I agree that this is a useful feature and should be added. I will add this as a feature request. Thanks.
Alexey Matveev
January 3, 2018
I just had a look at the code and I also could not find required by you routines. Try to open a ticket in the vendor support system.
