I got some issue with post functions for clone issue. I would like to get some values from orignal issue.
The exemples provided gives me a hint to use sourceIssue.*
Using for example issue.Summary = "Change: " + sourceIssue.summary
gives me this error
[canned.jira.utils.ConditionUtils] Condition failed on issue: IVY-5, built-in script:com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.CloneIssue
java.lang.NullPointerException: Cannot invoke method contains() on null object
at java_util_List$contains$3.call(Unknown Source)
at Script16.run(Script16.groovy:1)
JIRA version 6.3.6
Script runner version: 3.0.5
Can you give some advice how to solve?
Below are a few lines of code that I use to create a clone of an issue in the post function. Please note that issue
is available in the post function scripts and refers to the current issue.
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.IssueFactory def compAccessor = new ComponentAccessor() def issueFactory = compAccessor.getIssueFactory() // define clone def clone = issueFactory.cloneIssue(issue) clone.setSummary("[SR] " + issue.getSummary())
Geert
Hi @Geert_Graat does this work as intended? I am looking for the right way to clone issues ;)
Cheers
Michaela
I have used the code above successfully in the past, but currently we use the built-in clone an issue an links script as post action, which you can use without any coding.
Geert
It should be: issue.Summary not issue.summary although I'm not sure that's your problem.
Sorry, tag corrected and version information added to issue.
Please use the correct label. What version of the plugin and jira?
