Script Runner Issue Picker not displaying correctly in Issues Navigator
Garry May November 18, 2018
I've created a script runner Script Field based off the Issue(s) Picker item and while it works perfectly in Edit mode it only displays 'code' when presented as a column in the results of an Issues Navigator query?
E.g.
$cannedScript.getNavigatorViewHtml($issue, $customField, $fieldLayoutItem, $!value)
I followed this walk-through: Issue-picker
I though the problem might be Template related but Field editor doesn't let me select one and the Custom Field Details screen only has 1 choice "Issue Picker Searcher".
Does anyone know what I've missed/how to fix this?
The field is shown in it's various states below and is named "The Project"
ps. I'm running Jira Software (Server) v7.11.2 and Script Runner Add-On v5.4.39
Main Screen
The Edit Screen
The Issues Navigator (results table)
Daniel Yelamos [Adaptavist]
November 19, 2018
Hi Garry!
As far as I can see there are no logged bugs regarding this issue. I would suggest that you open a support request in our customer support portal to try and get some help from there.
Cheers!
DY
Garry May November 19, 2018
Thanks Daniel,
I've raised a Support Request as SRJSUP-6535
Will update the outcome here
Roman Kharytonov October 4, 2019
FYI, it's fixed in version 5.5.9
Antonio Bosio
When the problem will be solved?
Best Regards and thanks
Antonio
Jonny Carter
February 22, 2019
Keep a watch on https://productsupport.adaptavist.com/browse/SRJIRA-3091 . That's the bug report that came out of this.
