Script Runner Post Function Clone Issue
valeria cruz August 11, 2017
Hello!
I'm trying to create a clone issue in another project using script.
this is my script
cfValues['Derivar Tarefa']?.value == 'Incident'
def cf1 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Catalogo de Servicios - LAM'}
issue.setCustomFieldValue(cf1, sourceIssue.getCustomFieldValue(cf1))
def cf2 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Aplicación LAM'}
issue.setCustomFieldValue(cf2, sourceIssue.getCustomFieldValue(cf2))
def cf3 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio PIMS LAM'}
issue.setCustomFieldValue(cf3, sourceIssue.getCustomFieldValue(cf3))
def cf4 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio Policy Tool'}
issue.setCustomFieldValue(cf4, sourceIssue.getCustomFieldValue(cf4))
def cf5 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio GLI'}
issue.setCustomFieldValue(cf5, sourceIssue.getCustomFieldValue(cf5))
def cf6 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio LogViewer'}
issue.setCustomFieldValue(cf6, sourceIssue.getCustomFieldValue(cf6))
def cf7 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio Claim'}
issue.setCustomFieldValue(cf7, sourceIssue.getCustomFieldValue(cf7))
def cf8 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio Batch Module'}
issue.setCustomFieldValue(cf8, sourceIssue.getCustomFieldValue(cf8))
def cf9 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio PIMS Fixing'}
issue.setCustomFieldValue(cf9, sourceIssue.getCustomFieldValue(cf9))
def cf10 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio PIMS Person'}
issue.setCustomFieldValue(cf10, sourceIssue.getCustomFieldValue(cf10))
def cf11 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio PIMS Product'}
issue.setCustomFieldValue(cf11, sourceIssue.getCustomFieldValue(cf11))
def cf12 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio Interfaz'}
issue.setCustomFieldValue(cf12, sourceIssue.getCustomFieldValue(cf12))
def cf13 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio Vision'}
issue.setCustomFieldValue(cf13, sourceIssue.getCustomFieldValue(cf13))
def cf14 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio Report Vision'}
issue.setCustomFieldValue(cf14, sourceIssue.getCustomFieldValue(cf14))
def cf15 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio Sun System'}
issue.setCustomFieldValue(cf15, sourceIssue.getCustomFieldValue(cf15))
def cf16 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio Jenkins LAM'}
issue.setCustomFieldValue(cf16, sourceIssue.getCustomFieldValue(cf16))
def cf17 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Servicio ODM LAM'}
issue.setCustomFieldValue(cf17, sourceIssue.getCustomFieldValue(cf17))
def cf18 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Affects Version/s'}
issue.setCustomFieldValue(cf18, sourceIssue.getCustomFieldValue(cf18))
def cf19 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Emergencia'}
issue.setCustomFieldValue(cf19, sourceIssue.getCustomFieldValue(cf19))
def cf20 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Impacto'}
issue.setCustomFieldValue(cf20, sourceIssue.getCustomFieldValue(cf20))
def cf21 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Ambiente LAM'}
issue.setCustomFieldValue(cf21, sourceIssue.getCustomFieldValue(cf21))
def cf22 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Comportamento esperado'}
issue.setCustomFieldValue(cf22, sourceIssue.getCustomFieldValue(cf22))
def cf23 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Comportamento com erro'}
issue.setCustomFieldValue(cf23, sourceIssue.getCustomFieldValue(cf23))
def cf24 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Descrição passo-a-passo do erro'}
issue.setCustomFieldValue(cf24, sourceIssue.getCustomFieldValue(cf24))
def cf25 = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Tipo de Atendimento'}
issue.setCustomFieldValue(cf25, sourceIssue.getCustomFieldValue(cf25))
and i receive this message in log
2017-08-11 16:51:31,619 http-nio-8080-exec-29 ERROR b54037 1011x2651005x1 1rtofso 10.170.136.135,10.170.136.188 /secure/CommentAssignIssue.jspa [c.o.s.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: ALSD-12, actionId: 501, file: null
java.lang.NullPointerException
    at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:896)
    at com.atlassian.jira.issue.Issue$getCustomFieldValue$1.call(Unknown Source)
    at Script83.run(Script83.groovy:36)
Daniel Yelamos [Adaptavist]
August 23, 2017
Hello Valeria.
Those are a lot of customFields that you seem to be setting. Sadly for you, one of those is failing to give you the proper reference as you can see:
 "at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:896)"
This means that one of the customFields that you are getting is null. Let me explain:
issue.setCustomFieldValue(cf1,sourceIssue.getCustomFieldValue(cf1))
In that line cf1 is null, because you have failed to properly get a reference to that object. That means that in one of your lines like this:
The "find" operation is returning null.
Do you understand what I mean?
You need to run each one of the lines "def cf" in the script console untill you see which one gives you null. Then you will know which line of your script you need to fix.
I hope this helps.
Cheers
DYelamos
