ScriptRunner (Scripted Field) - Calculation using a numeric values and current Sprint
Darren Campbell
April 6, 2017 edited
We are trying to write a script for a scripted field.
Our scenario is that we have a custom number field (Sprint Variance) and a scripted one (Max Sprint).  Our Epic will be put into an current sprint variance will indicate that it may take up to x additional sprints before it’s resolved.  Based on the current Sprint Name (e.g. UI Sprint 34) and Sprint Variance (2), we want the scripted field to display (UI Sprint 36).
Obviously the assumption here is that the numbers are at the end of the sprint name and after the word "Sprint".  Does anyone have any ideas on how to write this script as I’m struggling to devise the correct syntax and methods :(
In advance I appreciate your help!
adammarkham
Please try the following code in a scripted field. This should do what you want, assuming Sprint Variance is a number custom field.
import com.atlassian.greenhopper.service.sprint.SprintIssueService
import com.onresolve.scriptrunner.runner.customisers.JiraAgileBean
@JiraAgileBean
SprintIssueService sprintIssueService
def sprintVarianceCf = customFieldManager.getCustomFieldObjectByName("Sprint Variance")
def loggedInUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def sprintResult = sprintIssueService.getActiveSprintForIssue(loggedInUser, issue)
def variance = issue.getCustomFieldValue(sprintVarianceCf) as Integer
def activeSprint = sprintResult.get().getOrElse(null)
def sprintName = activeSprint.name
if (! variance || ! activeSprint) {
    // variance or active sprint not set so no max sprint
    return null
def tokenizedSprintName = sprintName.tokenize(" ")
// remove old variance
def sprintNumber = tokenizedSprintName.pop().toInteger()
// calculate new variance
tokenizedSprintName.push(sprintNumber + variance)
// join tokens together
tokenizedSprintName.join(" ")
Let  us know how you get on with that.
Please also see our documentation around working with JIRA Agile here.
Darren Campbell
Hi Adam,
Unfortunately I get mulitple errors
adammarkham
April 6, 2017
Hi Darren,
They are just static type checking errors. The script will still work as expected when added and run.
Darren Campbell
It doesn't populate the field unfortunately
adammarkham
April 6, 2017
Are you on the view epic screen with a "Sprint Variance custom field set as a number custom field?
Also is your sprint called something like "UI Sprint 2"?
Then you should see this appear.
Do you see any errors in the log file when you view the epic?
Which version of JIRA and ScriptRunner do you have?
adammarkham
April 6, 2017
I edited the script a while ago, I think you have the old version. Please update it and try again.
Also the epic should be in an active sprint.
Darren Campbell
Copied and pasted provided run again but the field still doesnt display.
I'm the EPIC via the normal issue view screen
Current sprint is called SEPI Sprint 32
Logs show:
[onresolve.scriptrunner.customfield.GroovyCustomField] Script field failed on issue: SEPI-793, field: Max Sprint
groovy.lang.MissingMethodException: No signature of method: com.atlassian.greenhopper.service.sprint.SprintIssueServiceImpl.getActiveSprintForIssue() is applicable for argument types: (com.atlassian.jira.user.BridgedDirectoryUser, com.atlassian.jira.issue.IssueImpl) values: [MYEMAIL:10000, SEPI-793]
Possible solutions: getActiveSprintForIssue(com.atlassian.jira.user.ApplicationUser, com.atlassian.jira.issue.Issue)
at Script533.run(Script533.groovy:14)
adammarkham
April 7, 2017
Hi Darren,
What version of JIRA and JIRA Software/Agile do you have?
There's a few JIRA Agile versions where some of these methods were changed so that may be causing the issue. Let me know and I'll provide an alternative.
Darren Campbell
Our JIRA version is 6.4.7 and Scriptrunner is 4.1.3.24
adammarkham
April 7, 2017
You should use the following script for JIRA 6:
@JiraAgileBean
def loggedInUser = ComponentAccessor.getJiraAuthenticationContext().getUser()
return null
Only change was this line:
JIRA 6 and 7 have different users either an ApplicationUser or directory User.
Darren Campbell
Aplogies for the delay...been on annual leave
Thanks, this works!!
