Sign up Log in
Setting Power Custom Field Pro value from groovy
Tyler Miller
I have an existing groovy script that creates issues, however I cannot seem to figure out how to set a value of a KCF pro field. It seems to require the value to be in com.keplerrominfo.jira.plugins.keplercf.pro.optionscf.customfield.SocOptionImpl, however that class is not being exported. Is there a trick to be able to get and set the value from these fields?
I have a hack in place right now, where I create the issue with groovy, then have a SIL listener on the create event that copies the value from another field.
I tried porting over my groovy script to SIL a while back, however there were a few functions missing in SIL that prevented me from doing so. So for now I am stuck with groovy.
Alexandra Topoloaga
August 31, 2017
The values of KCF Pro fields are structures of KPOption type, which means they come in (label, value) pairs.
So, in order to set the value you must provide a label and a value.
It should be similar to how we set the default values for the fields, an example is here
Hope this helps,
Alexandra
Tyler Miller
That was actually the first thing I tried. But when passing the value as string.
'{"label":"","value":"10000"}' I get an error:
java.lang.ClassCastException: java.lang.String cannot be cast to java.util.Collection
at com.keplerrominfo.jira.plugins.keplercf.pro.optionscf.customfield.SILOptionsCFtype.valuesEqual(SILOptionsCFtype.java:60)
at com.atlassian.jira.issue.fields.CustomFieldImpl.valuesEqual(CustomFieldImpl.java:1601)
at com.atlassian.jira.issue.fields.CustomFieldImpl.updateValue(CustomFieldImpl.java:462)
at com.atlassian.jira.issue.fields.CustomFieldImpl.updateValue(CustomFieldImpl.java:434)
at com.atlassian.jira.issue.managers.DefaultIssueManager.updateFieldValues(DefaultIssueManager.java:704)
at com.atlassian.jira.issue.managers.DefaultIssueManager.updateIssue(DefaultIssueManager.java:669)
at com.atlassian.jira.issue.managers.DefaultIssueManager.updateIssue(DefaultIssueManager.java:655)
at com.atlassian.jira.issue.IssueManager$updateIssue$0.call(Unknown Source)
at Script221.run(Script221.groovy:39)
When I pass it [label:"",value:"10000"] I get:
java.lang.ClassCastException: java.util.LinkedHashMap cannot be cast to java.util.Collection
and when I pass it [[label:"",value:"10000"]] i get:
java.lang.ClassCastException: java.util.LinkedHashMap cannot be cast to com.keplerrominfo.jira.plugins.keplercf.pro.optionscf.customfield.SocOption
at com.keplerrominfo.jira.plugins.keplercf.pro.optionscf.customfield.SILOptionsCFtype.convertTypeToDbValue(SILOptionsCFtype.java:60)
at com.atlassian.jira.issue.customfields.impl.AbstractMultiCFType.convertTypesToDbObjects(AbstractMultiCFType.java:190)
at com.atlassian.jira.issue.customfields.impl.AbstractMultiCFType.updateValue(AbstractMultiCFType.java:142)
at com.keplerrominfo.jira.plugins.keplercf.pro.optionscf.customfield.SILOptionsCFtype.updateValue(SILOptionsCFtype.java:304)
at com.keplerrominfo.jira.plugins.keplercf.pro.optionscf.customfield.SILOptionsCFtype.updateValue(SILOptionsCFtype.java:60)
at com.atlassian.jira.issue.fields.CustomFieldImpl.updateValue(CustomFieldImpl.java:464)
the ouput of a getCustomFieldValue where it's already set gives me:
[SocOptionImpl{label='', value='25002'}]
